phil_ashworth
Message 1 of 16
BT Infinity 2 problems
Yesterday (Friday 5th June) our infinity connection was finally enabled on our connection. We had waited 4 months since the first cabinet on our exchange to be enable and ours was the last. So we were very keen to see if there was an improvement on our 5 down and 0.3 up, we were very skeptical as we have had problems with BT in the past. Our first test showed a massive improvement on the upload, it had increased to 5 up! (And I know the connection speeds vary in the first week or so) but 5 was good enough for now even though we were promised higher. Now we get on to the download, other people I knew on our exchange but a different cabinet said that initially they got 35 down on BT Infinity 2 but it has now maxed out at 75 down. We on the other hand are getting between 8 - 12 down. This to me seems very low for an initial speed and I can't see how we would ever get near 76 down if our initially speed isn't even in double digits?! Also our connection kept restarting every half an hour during that evening and continues to do so this morning. Also when the connection was actually working alright last night, I was getting 80% loss on the connection and 200 ping when I was gaming. I can tell you that isn't fun to use.
TL;DR - Before fibre we got 5 down and 0.3 up, we are paying for BT Infinity 2 and are now getting 12 down and 5 up. We are skeptical whether our connection will ever reach anything near 76 down. Also a couple other connection issues.
15 REPLIES 15
imjolly
Message 2 of 16
Re: BT Infinity 2 problems
enter your phone number and post results  remember to delete your number  https://www.btwholesale.com/includes/adsl/main.html
go to troubleshooting then helpdesk and post 1-12
phil_ashworth
Message 3 of 16
Starting to think I should downgrade to BT Infinity 1 😞 so long for waiting 6 months for nothing
imjolly
Message 4 of 16
you can see from your estimate that at best you can get 30mb connection speed so yes you should downgrade to infinity 1  call options team 0800800030 they are uk based and will help you
imjolly
Message 5 of 16
was this a self install?  if so are you using the test socket with a new filter or do you have a SSFP?
phil_ashworth
Message 6 of 16
Self install and yeh I will downgrade then
imjolly
Message 7 of 16
so are you using test socket?
phil_ashworth
Message 8 of 16
i am using one of the filters that came with the new hub
imjolly
Message 9 of 16
ok but are you using test socket or somewhere else?  or do you have a socket like this  fibre SSFP.jpg
phil_ashworth
Message 10 of 16
I am using the standard one port thing. Not the one with two ports.
