Message 1 of 10
BT Infinity 2 speed drop from 77 to under 50
9 REPLIES 9
Message 2 of 10
Re: BT Infinity 2 speed drop from 77 to under 50
Bt wholespeed test is under 50 but ping and upload are still good, this is a wired connection
Sage
Message 3 of 10
Does this happen all day or just at certain times? Other than the speed drop is it causing you any problems?
Message 4 of 10
All day for 3 days
Message 5 of 10
Have you tried a reboot?
Message 6 of 10
noise margin looks high possible DLM action
Message 7 of 10
Unlikely. Doesn't seem to be a banded profile.
Could have been a noise spike which caused the lower sync.
Max attainable is massive, so no line fault present.
I'd attempt one reboot.
Message 8 of 10
I rebooted it a couple of times
Message 9 of 10
how can this be fixed?
Moderator
Moderator
Message 10 of 10
@olivergough Please use the 'click here to contact the mods' link in my forum profile to send in your details and we'll be happy to help. You can find the link by clicking on my username.
Neil
