Vankwish
Message 1 of 8
BT Infinity 2 speed drop (linestats included)
Been on BT Inifinity 2 for a few years, and it has been good (64 down 20 up) and rock solid . . . .
. . . . untill about 3 weeks ago.
Speeds dropped to 30 down 0.8 up, latency shot through the roof!
Tried calling - got nowhere after being disconnected several times! Smiley Mad
Tried online support - a little better, just over a week ago an engineer visited and i waited patiently for an update or at least better speeds but alas still nothing.
This weekend purchased a new modem with linestats as the speeds atayed the same and i heard nothing back from BT.
The stats show;
xDSL
ModeVDSL2
Traffic TypePTM
StatusUp
Link Power StateL0
 DownstreamUpstream
Line Coding (Trellis)OnOn
SNR Margin (dB)16.418.1
Attenuation (dB)18.50.0
Output Power (dBm)13.65.3
Attainable Rate (Kbps)6507312543
Rate (Kbps)29996800
B (# of bytes in Mux Data Frame)4712
M (# of Mux Data Frames in an RS codeword)11
T (# of Mux Data Frames in an OH sub-frame)641
R (# of redundancy bytes in the RS codeword)1616
S (# of data symbols over which the RS code word spans)0.05090.4781
L (# of bits transmitted in each data symbol)10064502
D (interleaver depth)127337
I (interleaver block size in bytes)6430
N (RS codeword size)6430
Delay (msec)164
INP (DMT symbol)8.004.50
OH Frames269053475100809
OH Frame Errors10
RS Words25927246611409833
RS Correctable Errors25535135811823948
RS Uncorrectable Errors10
HEC Errors00
OCD Errors00
LCD Errors00
Total Cells6907669930
Data Cells9225959740
Bit Errors00
Total ES10
Total SES00
Total UAS3030
The 'attainable rate' looks alot like the download speed i was getting a month ago, how do i get it back?
Please someone help me help myself!
7 REPLIES 7
imjolly
Message 2 of 8
Re: BT Infinity 2 speed drop (linestats included)
You are in a banded profile probably due to your connection dropping often or manual resets or. Combination of both
This will recover automatically with noise margin dropping down to normal 6db and speed increasing nearer attainable  this could take a few weeks to happen ghough. You need a stable connection 24/7 with no resets
Vankwish
Message 3 of 8
Thank you for that, I guess switching to a new modem didn't help the recovery after all!
But I must say its much more responsive than the HH5 and has some nifty features (alongside linestats).
Should i see the same improvement in my latency?
imjolly
Message 4 of 8
All the resets have resulted in deep interleaving being applied and that will take even longer before the interleaving depth reduces
Vankwish
Message 5 of 8
I guess its just wait it out then Smiley Happy
It would have been usefull for the engineer to have explained that to me when he visited, as i have never had any problems with infinity i just assumed that it was the same process as ADSL.
imjolly
Message 6 of 8
With adsl the forum mods would be able to help with the banded profile and latency but with vdsl it is controlled by the DLM you need a broadband  engineer visit and a problem fixed before engineer can get DLM reset.
A phone engineer as against a broadband engineer cannot get DLM reset
Vankwish
Message 7 of 8
Hello,
Its been some time . . .
Unfortunatley my line speeds have still not improved. I still have the stats previously posted but the speeds remain drastically lower than previous to this issue.
Please help!
Thank you
Webby
Message 8 of 8
You need an engineer visit
