MJR1990
Message 1 of 6
BT Infinity 4... very slow so far
Okay so I've had FTTP installed this morning, 8 hours later I'm getting 30mb rather than 300mb.
Is this normal or should I be worrying/changing something?
5 REPLIES 5
john46
Message 2 of 6
Re: BT Infinity 4... very slow so far
can you please run the further diagnostics part of the BT speedtest with a wired connectionand post the results
http://speedtest.btwholesale.com/
MJR1990
Message 3 of 6
Hi there,
Thanks for the reply. It's much better than my wifi so thanks for pointing that out, but still half the speed I was expecting?
john46
Message 4 of 6
give the connection 24 hours could you also post the further diagnostic part of the speed test
MJR1990
Message 5 of 6
Thanks, I will be patient until tomorrow 🙂
I couldn't do the second part of the test, I got this error with my address:
"The Performance Test cannot proceed with the Post Code option as no suitable addresses have been found. Please check the post code or use the Service ID option to conduct the test."
Not sure where to find my service ID?
john46
Message 6 of 6
the service ID is only known to Openreach/providers it may take a few days to update before you can use part 2 of the test
