MONSIEUR007
Message 1 of 4
BT Infinity HH2
I have a BT Infinity Home Hub 2.0, I have connected my Seagate HDD to the usb socket.  It has been formatted to FAT32.  When I try to Map it to my network with the address 192.168.1.253/bt_7g, I can hear the HDD working but get a message to say the following
'Your computer appears to be correctly configured but the device (HDD) or resource (192.168.1.253) is not responding'
I feel I'm almost there but can't quite access it.  I have a Window 7 laptop.
Your help is very much appreciated.
Tags (3)
3 REPLIES 3
PC
Recognised Expert
Message 2 of 4
Re: BT Infinity HH2
There is some info below... it's for the HH3 but I would think they would be the same for this sort of thing.
http://community.bt.com/t5/BT-Infinity/HH3-USB-question/m-p/233533/highlight/true#M9970
http://community.bt.com/t5/BT-Infinity/Using-and-external-hard-drive-with-Home-Hub-3/td-p/330681
Please Click On any Text in Blue as that automatically links to information.
PC (NDEGR)
MONSIEUR007
Message 3 of 4
Re: BT Infinity HH2
Thanks, will give that a go.
MONSIEUR007
Message 4 of 4
Re: BT Infinity HH2
Thank you, that worked perfectly Smiley Happy
