richm
Newbie
Message 1 of 2
BT Infinity Installation...
Hi, I am due to have infinity installed this week. I live in a 3 story town house with the master socket located on the first floor landing. My O2 Box and Vodafone booster are currently located here... I have 3 power points located next to the master socket..
I presume no additional cabling will be required as I have power right by my master socket?
Rich
1 REPLY 1
ypt
Message 2 of 2
Re: BT Infinity Installation...
Hi Rich,
You'll need a socket for the modem power supply and a socket for the BT Home Hub.
It is advisable to ask the installation guy to fit the modem as wall mounted - the original modems were prone to overheating - the newer ones seem to be better, but wall mounting gives better ventilation.
Will the Hub be on or off the floor? the higher the better for wifi distribution.
Hope this helps
Michael
