ChipRivers
Message 1 of 15
BT Infinity Installation
I have recently placed an order to upgrade to BT Infinity which will be installed late in January.  I have been giving consideration to the placement of the new equipment to ensure maximum performance whilst maintaining the convenience of connection to other equipment such as my wireless printer and Vodafone Sure Signal.
My BT master socket is the cupboard under the stairs; there is power sockets in this location so if necessary I can have the equipment all fitted here but it would not be as easy to connect my extra equipment to the Home Hub.
I currently have my Home Hub plugged into an extension socket in my front room where I also have my printer and VSS connected.
Ideally I would like to keep my HH in the same location in the front room; can this be done without having to have the free 'upto 30m cabling' running around skirting etc?  Can the engineer make use of the existing extension socket and if so will this effect by infinity speed?
14 REPLIES 14
Deathtrap3000
Recognised Expert
Message 2 of 15
Re: BT Infinity Installation
If you arent already getting the full speed at the master socket, any extensions you have for the broadband will slow your speed down. They should be able to use your existing extension for infinity with no problems.
Ogier
Message 3 of 15
If I may suggest.
Would it not be more prudent if the modem is attached "at source" so to speak, then the HH can be routed via the Network cable from the modem?
Just a thought
Good luck anyhow
Ogier
ChipRivers
Message 4 of 15
Thanks for the suggestion, not sure I know what you mean though Smiley Indifferent
Do you mean put the new Open Reach Infinity modem in the cupboard under the stairs where the master socket is, and then use CAT5 cables to run to the HH3 in the front room where I currently have the HH2?
My only problem with this is the visibility of the CAT5 cable.
Ratty2012
Recognised Expert
Message 5 of 15
You could always have both the modem and the HH3 in the cupboard and connect to them using homeplugs. That way no additional wiring is required.
ChipRivers
Message 6 of 15
By 'homeplugs' do you mean the powerline adaptors like what I use for my BTVision?
If so, do these only work in pairs or can I have several devices with additional adaptors connected to the single source adaptor?
Ratty2012
Recognised Expert
Message 7 of 15
Yes, BT like to call them powerline adaptors, but in fact they are called homeplugs.
You can have as many of them as you want. I have seen some setups where over 30 of them have been used.
It would be better to get them from a single source.
ChipRivers
Message 8 of 15
So it sounds like putting both the modem and hh in the cupboard and using homeplugs will be the best solution to maximise my download speed.
My only other consideration is how much effect on my wirless signal strength will there be shutting the HH away in the cupbaord under the stairs?
Ratty2012
Recognised Expert
Message 9 of 15
You could always get a homeplug wireless adapter: http://www.devolo.co.uk/consumer/100_dlan-500-av-wireless_starter-kit_product-presentation_1.html?l=...
This will enable you to use wireless without loosing your singal because your homehub is in the cuboard
Guru
Message 10 of 15
Not really true, as some companys market them as powerline adaptors.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
