Message 1 of 19
BT Infinity Issues - Slower than standard broadband?????
Man Sad
Can anyone help or give me some assurances that things will improve?
I have been with BT since 25th Feb on an infinity line that tests at 38Mbps downstream.  My old broadband connection was at a minimum of about 5.8Mbps.  Why is it then that my brand new, fibre optic, all singing , all dancing, more expensive BT Infinity connection is only giving me 2Mbps?!?!?!
This speed was checked with BT's own speed tester, my MAC is on a wired connection to the hub and the test was carried out at an off peak time (11.20am on a Wednesday) and yet, I could get a faster connection with a piece of string and 2 **bleep** cups!
Please, please, please tell me this is a blip and something that can be easily sorted by calling someone at BT?  If so, please can someone let me have a number to call as the tech services guy I just spoke to seemed to think that 2 Mbps on an Infinity connection was good!!!
Any help would be MASSIVELY appreciated.
Cheers.
Smiley Mad
18 REPLIES 18
Message 2 of 19
Re: BT Infinity Issues - Slower than standard broadband?????
what sort of connection speed did you have when the engineer was at your home installing the equipment?
Message 3 of 19
on his line test (direct into the socket) he got 33.2Mbps and on a on-linee speed test on the MAC I got 26.9Mbps!
Message 4 of 19
is it possible for you to run btpeedtester and post the results?  at least we know the connection to your home was ok when the engineer was there
Message 5 of 19
have tried to run another one (the muppet at BT technical support asked me to run one about 2 hours ago) and I got the following message:
null
You appear to be logged in as bthomehub@btbroadband.com. In order to run the next test you must login as speedtest@speedtest_domain.
Please wait while you are redirected..
Any ideas how to rectify this on a MAC???
Message 6 of 19
is that using this  http://speedtester.bt.com/
Message 7 of 19
Yeah.
I shut down and re started the browser and then the MAC and it has now let me do it!
Results are:
FAQ
Results Image not loaded
Test1 comprises of two tests
1. Best Effort Test:  -provides background information.
Download Speed
3281 Kbps
0 Kbps38717 Kbps
Max Achievable Speed
> Download speedachieved during the test was - 3281 Kbps
 For your connection, the acceptable range of speedsis 12000-38717 Kbps .
 Additional Information:
 IP Profile for your line is -38717 Kbps
2. Upstream Test:  -provides background information.
Upload Speed
1582 Kbps
0 Kbps2000 Kbps
>Upload speed achieved during the test was - 1582 Kbps
 Upstream Rate IP profile on your line is - 2000 Kbps
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
Any suggestions???
Message 8 of 19
well you have a 38mb connection (green with envy) but your throughput/download is only 3.2mb.  check your exchange here for problems  http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
if there are no problems shown then you need mod assistance.  just fill this out  http://bt.custhelp.com/app/contact_email/c/4951
Message 9 of 19
have checked the exchanges and they are all clear so will fire off the form and keep my fingers crossed that I haven't wasted a lot of time and money by moving to BT.
Message 10 of 19
your speed will be sorted and you will have a download the envy of the majority on the forum membersSmiley Wink
