Message 51 of 496
Re: BT Infinity Northern Ireland
Hi
Further to my last post I checked www.samknows.com for you and it says that Castlewellan exchange has been enabled for fttc. I would ring BT and see the latest postion. Let us know how you get on.
Ian
Message 52 of 496
Hi All
Check this site out its BT Openreach.
http://www.openreach.co.uk/orpg/products/nga/downloads/fttc_pot_exchs.pdf
it may give some of you more information.
Ian
Expert
Message 53 of 496
@ ijjsimpson
Thanks for the info mate...I have been checking these sites out for some time along with http://www.kitz.co.uk/adsl/adslchecker.php
which, again gives a different result...sam knows said previously it was available, then changed to not available, and about 2 weeks ago changed back to "available"....The BT wholesale line checker was similar (available ->not available-> Oct 31st)...Fasterbroadbandni.com has been swapping dates too..
I spoke to a BT engineer working on the cabinet in the Square in C'wellan last week and asked him...He said KN networks have been replacing the shells on the old GPO cabinets but the innards were the same...He didn't have a clue as to when it was coming (Infinity) but it is DEFINITELY not available yet as there are NONE of the new type cabinets in the area yet...my Girlfriend in Crossgar is getting it (Infinity LOL) and there is one of the brand spanking new cabinets at the end of her drive...
So until I see the new cabinet erected beside my nearest cab I don't beleive sam knows or indeed BT wholesale..When I check the Infinity site and it says it's available, then I will order...
BTW...Is it sales I ring and what is the number and I'll ring it tonight?
Message 54 of 496
Just got BT infinity installed this morning
Getting around 16mbit/sec down and 5mbit/sec up
Message 55 of 496
wot were your speeds like before u got infinity.
Tags (2)
Message 56 of 496
by the way folks,wot u think of my adsl settings good r bad.i haven,t a clue wot they mean.
ADSL line status
Connection Information
Line stateConnected
Connection time0 days, 10:03:41
Downstream608 Kbps
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.1 Annex A
Latency typeInterleaved
Noise margin (Down/Up)8.2 dB / 11.0 dB
Line attenuation (Down/Up)72.0 dB / 31.5 dB
Output power (Down/Up)1.1 dBm / 1.2 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)272 / 157
CRC Errors (Down/Up)2 / 17
HEC Errors (Down/Up)3 / 7
Error Seconds (Local/Remote)2 / 8
thanks
phil...
Message 57 of 496
Used to get 6mbit/sec down and 800kbit/sec up on total bb option 3, went down to 0.5mbit/sec for last 2 weeks.
Message 58 of 496
i would be over the moon if i got 6mb dl speed.the fastest dl speed i ever got was 0.90kbps,so i have a lot riding on infinity when i get it installed next month.personally if i was to go up to 3,or 5 mb dl speed i would be over the moon lol.
Tags (1)
Message 59 of 496
Hi
What part of NI are you in?
Ian
Expert
Message 60 of 496
@ ijjsimpson
Rang the number you gave me and got through to Aileen...very helpful lady and it's great to talk to someone when there is no accent barrier...Smiley Wink
She says my cabinet will be ready on the 31st October and I can place an order for infinity then.....whoopeee!!!
