ijjsimpson
Message 1 of 496
BT Infinity Northern Ireland
Hi All
Anybody got new information on the progress of fibre rollout in areas in Northern Ireland pls post so we all can at least guess we it will be available. Latest date for NIBMS is 30/09/2010, hopefully cabinet 5 is inline for same date.
Annahilt Co, Down area. Anybody around this area with more information please post.
Thx Ian
495 REPLIES 495
lushman0
Message 2 of 496
Re: BT Infinity Northern Ireland
Hi,
Check here, but I didnt see Annahilt on the list
http://www.fasterbroadbandni.com/
Tags (1)
belfastbloke
Message 3 of 496
well i,m n drumaness and i,m getting hopefully switched on 5/10,thats when the bt bloke is coming out to the house.
ijjsimpson
Message 4 of 496
Hi
Thx for post, Annahilt is supplied by the ballliesmills exchange. NIBMS is its BT title.
Ian
ijjsimpson
Message 5 of 496
Hi Belfastbloke
Thats good, I would imagine Ballynahinch will be before you so not long now.
Ian
belfastbloke
Message 6 of 496
Did they give u a date when ballynahinch would be getting it.
ijjsimpson
Message 7 of 496
Hi
No but Annahilt is due to get fttc on 30/09/2010 so assuming then it goes on to ballynahinch then out to drumaness, I think that would be logical. Check with www.fasterbroadbandni.com and select ballynahinch from drop down menu at bottom and it will tell you expected date of upgrade.
Ian
belfastbloke
Message 8 of 496
P1SPA CROSS ROADSBT24 8QAJan 31st 2011
P10DUNMOREBT24 9PYJan 31st 2011
P15CUMBER GDNSBT24 8RNJul 31st 2010
P16LANGLEY RDBT24 8DAApr 30th 2010
P2CROSSGAR RD/BALLYLONE RDBT24 8TXApr 30th 2010
P3DRUMHILL AVEBT24 8EHApr 30th 2010
P6ENTRANCE TO NEWBT24 8LWJul 31st 2010
P7JCN DRUMANESS RD &BT24 8SZJul 31st 2010
this is wot i get when i type ballynahinch,so i take it i,m the JCN DRUMANESS RD,which means that the bloke from bt meant that the 5/10 is the next available date for an engineer to call out to install it.i only hope its better than wot i get now,which is paramout to dialup.
belfastbloke
Message 9 of 496
sorry i would be cumber gdns.
ijjsimpson
Message 10 of 496
Hi
When you check with BT Infinity checker what date do you get?
Ian
