Message 1 of 26
BT Infinity Option 2 - new customer- extreme slow download speed at 'peak' times
Good afternoon.
I got Infinity Option 2 installed on the 12th and when it's good, I get about 68/18, however, after 5pm it often drops to to 3-15/7-12) based on analysis of speedtest.wholsesale.bt.com
I notice it as a detriment to even receiving the odd email!
I expect a drop at peak time, but I think this is far too extreme.
I'm happy to engage in the tests , but not sure where to start.
25 REPLIES 25
Message 2 of 26
Re: BT Infinity Option 2 - new customer- extreme slow download speed at 'peak' times
go to hub manager then troubleshooting then helpdesk and post stats 1-12
enter your phone number and post results  remember to delete number  https://www.btwholesale.com/includes/adsl/main.html
run btspeedtester and when first test completes then run diagnostic test and post results
btspeedtester
Guru
Message 3 of 26
Can you run that speedtest, and when complete run the 'Further Diagnostics' and post the results, please?
Are you running wired or wireless?  If at all possible run tests wired; there are so many extra variables with wireless.  For example, it may be that a neighbour turns on a wireless router or other interfering device at 5pm, or your central heating turns on with a dodgy pump, or ...???
Message 4 of 26
Thanks. I will carry out later on this evening.
I do all my tests with wireless disabled , wired conncetions. Thanks
Until then, is this an 'acceptable' swing in permance at peak times? Just so I can set expectations.
Message 5 of 26
if you were using a wireless connection then it is more than likely it will fluctuate based on changing conditions  only way to really check is with a wired connection
Message 6 of 26
I'm sorry, a mis-placed comma may have changed the interpretation of my post.
I do all of my tests with wireless disabled. I do my tests only with wired connections.
Message 7 of 26
ok
please post the information
Message 8 of 26
1. Product Name: HomeHub5
2. Serial number: +076284+1418001581
3. Firmware version: v0.07.01.0235-BT (Type B) Last updated [Unknown]
4. Board version: 01
5. VDSL uptime: 1 days, 19:20:40
6. Data Rate: 20000 / 74170
7. Maximum Data Rate: 24452 / 89194
8. Noise Margin: 9.1 / 6.1
9. Line Attenuation: 0.0 / 18.3
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 502.1 MB / 1.5 GB
12. Broadband username: bthomehub@btbroadband.com
Message 9 of 26
Telephone Number 01592xxxxxx on Exchange GLENROTHES CENTRAL is served by Cabinet 16
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date  High Low High Low
FTTC Range A (Clean)8072.62020--Available
FTTC Range B (Impacted)8062.42019--Available
WBC ADSL 2+Up to 3.5--2.5 to 4.5Available
WBC ADSL 2+ Annex MUp to 3.5Up to 0.52.5 to 4.5Available
ADSL MaxUp to 3--2 to 5.5Available
WBC Fixed Rate1----Available
Other Offerings
Fibre Multicast------Available
Copper Multicast------Available
Message 10 of 26
BTW Performance Test @ 22:02
D 4.62
U 8.55
latencey 193.ms
