Message 11 of 26
Re: BT Infinity Option 2 - new customer- extreme slow download speed at 'peak' times
 Download speedachieved during the test was - 4.62 Mbps
 For your connection, the acceptable range of speedsis 60 Mbps-71.79 Mbps .
 Additional Information:
 IP Profile for your line is - 71.79 Mbps
Upload speed achieved during the test was - 8.55Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
Message 12 of 26
I'm struggling to get the tap3 test to work.
I can connect using speedtest@speedtest_domain with no password, but when clicking continue on the tap3 test page, it just times out
Message 13 of 26
Sorry folks
I tried a few more times connected as speedtest@speedtest_domain  (router connects ok - turns blue) but page just wont load. I made sure I was getting DNS from my router, to no avail
Message 14 of 26
BTW Performance Test @ 22:44
D 7.65
U 7.33
latencey 63.ms
Message 15 of 26
however my notes from 20th September at 15:54
😧 64.33
IP Profile 67.73
U: 15.28
IP Profile 15.28
Message 16 of 26
Hi folks
Any thoughts?
Distinguished Guru
Message 17 of 26
Possibly exchange congestion
If not, I'll try again 🙂
Message 18 of 26
I'm guessing that,
One of my original questions is , is this acceptable for the amount I'm paying?
What are the guidelines ?
Message 19 of 26
You're connected at that speed with that attenuation... My attenuation is 15.8 but max I can get is 64.
Message 20 of 26
Hi.
I am not sure what you are implying by your comment . Do my line stats indicate an issue ?
