Newbie
Message 1 of 3
BT Infinity Replacement Router and Modem
Hi.... or Help!!
I have BT Infinity running through Homehub 3 and wish to replace router and modem, I was advised to get a TP Link AC1750 (ADSL2+ Modem Router) but cant for the life of me get it to connect to the internet.
I have followed the quick Set Up process, used the correct password and user name for BT but all I see on the modem is the wireless light (good sign) and flashing ADSL light which suggests its connecting(?) but never does.
Any ideas??
Cheers
2 REPLIES 2
Message 2 of 3
Re: BT Infinity Replacement Router and Modem
Whoever advised you to get an ADSL modem/ router for a VDSL service gave you very bad advice. It won't work on Infinity. You need a VDSL modem/ router.
Message 3 of 3
If you are looking for a high-end TP Link you could consider the VR900, if you just want cheap and cheerful there is the TD-W9980.
