THOMAS-P
Message 1 of 3
BT Infinity Set Up
Hi, This is bugging me a bit.
I had BT Infinity installed today. I have 2 phone sockets in my living room. The master socket is next to 2 plug points which are in use, so i asked if the master could be moved to the socket the other side of the room (4 plug points not being used next to it). The engineer did this no problem but now the old master socket does not work.
Should it have been left like this? The new socket has also been fitted wonky which is a pain in the **bleep**.
2 REPLIES 2
Devon_Dave
Distinguished Guru
Message 2 of 3
Re: BT Infinity Set Up
Did you ask the engineer to make the original master socket an extension?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
THOMAS-P
Message 3 of 3
Nope, Just thought that would be part of the service rather than leaving a void phone socket.
