mct-panlane
Message 1 of 16
BT Infinity Slow Speed
I have just upgraded to BT Infinity 1 with a HH5. My previous ADSL download spped was 2.7 Mbps. On BT Infinity I am now getting 6.5 Mbps. this is far below the pre contract estimate of 18 - 25 Mbps and very disapointing.
The BT Wholesale diagnostics says,
Download speed 6.54
Acceptable range 4.72 - 6.75
IP profile 6.75 max
Upload speed 1.17
IP profile 10.0 Mbps max
This is via a LAN connection.
India chat line no help, they just say wait ten days.
Any sugestions ?
15 REPLIES 15
Keith_Beddoe
Message 2 of 16
Re: BT Infinity Slow Speed
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Then, if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post lines 1-12
imjolly
Message 3 of 16
Are you using the test socket with a new filter to eliminate internal wiring problems
Lightningpete
Message 4 of 16
I have a feeling distance is his issue as 2.7 is very low for ADSL these days.
If its Fibre to the Cabinet FTTC connection then I imagine he has a long distance from his exchange.
It might be handy however to tell the BT techies on this forum to change your internet profile and turn off download management (which is used to stabilise the connection for things like streaming... But it doesnt actually work).
You may see double the speeds your getting.
Lightningpete
Message 5 of 16
(I meant DLM)
gg30340
Message 6 of 16
The distance to the exchange has no relevance on a FTTC connection. It is the distance to the cabinet that matters.
When you say   "change your internet profile and turn off download management (which is used to stabilise the connection for things like streaming"  there is no such option on FTTC connections. DLM is an automated process and the ISP have no control over it.
mct-panlane
Message 7 of 16
BT BROADBAND AVAILABILITY CHECKER
Telephone Number  on Exchange HANNINGFIELD is served by Cabinet 1
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  HighLowHighLow
ADSL Products
Availability Date
Left in Jumper
Other Offerings
Availability Date
VDSL Range A (Clean)24.61853.2--Available----
VDSL Range B (Impacted)18.78.641.1--Available----
WBC ADSL 2+Up to 2--1.5 to 4Available--Yes
WBC ADSL 2+ Annex MUp to 2Up to 0.51.5 to 4Available--Yes
ADSL MaxUp to 1.5--1 to 3.5Available----
Fixed Rate0.5----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
mct-panlane
Message 8 of 16
1. Product Name: HomeHub5
2. Serial number: +076286+1611000139
3. Firmware version: v0.07.05.0A13-BT (Type B) Last updated 20/7/2016
4. Board version: 01A
5. VDSL uptime: 0 days, 14:16:06
6. Data Rate: 1269 / 6973 7. Maximum Data Rate: 1269 / 9304
8. Noise Margin: 6.4 / 10.4
9. Line Attenuation: 19.5 / 35.2
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 47.7 MB / 322.5 MB
12. Broadband username: bthomehub@btbroadband.com
imjolly
Message 9 of 16
Can you post stats from hh5 go to hub manager then troubleshooting then helpedesk and post stats
imjolly
Message 10 of 16
Beat me to it
Are you using the test socket with a filter?
