Recognised Expert
Message 11 of 15
Re: BT Infinity Speed.... Dropping
@micksea173 wrote:
Those test have been done wired using the speedtest.btwholesale.com.  I have been told to use that in the e-mail I recieved from BT customer services.
For Infinity you should use: http://www.speedtester.bt.com/ for your speedtests because not only does it show your download and upload speed, it also shows you what download and upload profiles you are on.
Distinguished Expert
Message 12 of 15
The difference is that speedtest.btwholesale.com uses flash and speedtester.bt.com uses java.
Both work and both return the profile.
To say thanks for a helpful answer, please click the white star
Recognised Expert
Message 13 of 15
Please check your facts before posting comments.
Note from the pics below that the wholesale speedtest does not show the profiles.
speedtester.bt.com:
Wholesale:
Sage
Message 14 of 15
The two of you should check your facts. With the BT Wholesale tester you have to click further diagnostics to get the IP Profile.
Moderator-Retired
Message 15 of 15
Please remain on topic and help the OP instead of spamming their thread with arguments.
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
