domjoy182
Message 21 of 32
Re: BT Infinity Speed Issue, possibly DLM
Think I'm back up and running. Just waiting for homehub to sort itself out and start issuing IP addresses again
domjoy182
Message 22 of 32
@smf22 Do you know if there is a reason I never see the option to run further diagnostics on a wholesale speedtest?
domjoy182
Message 23 of 32
managed to get on diagnostics
bit confused is the max speed i can get 28.39 or 80??
licquorice
Message 24 of 32
You should be getting somewhere between 66 and 80, what do the stats from the modem show? There are instructions on Kitz if you are not sure how to get the stats.
domjoy182
Message 25 of 32
Just managed to unlock modem but now my speed has dropped to 7 meg. Will get the stats now
domjoy182
Message 26 of 32
@licquorice here are my basic stats. Is this what you were after?
licquorice
Message 27 of 32
Should have asked this before, are you connected to the master socket or an extension? Can you try connecting the modem to the test socket behind the removable faceplate of the master.  Your line speed is nothing like you should be getting but your snrm looks OK.
domjoy182
Message 28 of 32
As far as I know it is the master socket. It is badged up openreach. there is one in the master bedroom that Id assume that is an extension as its an old style phone socket.
Okay I will run a wired test with modem direct to test socket
domjoy182
Message 29 of 32
Here is the result from test socket.
domjoy182
Message 30 of 32
Does this wiring look right with the loose unconnected ends?
