Message 1 of 10
BT Infinity Speed Issues - Again!!
I pay for the top of the range BT Infinity package that states that I should get 75MB download speeds. The last couple of months I have I had varying speeds from 58MB to 75MB. BT comes to fix it, speed goes back up to 75MB and after a few weeks it goes down again. Has anyone else had this problem too?  If so, how can I get BT to fix the issue permanently?
9 REPLIES 9
Distinguished Guru
Message 2 of 10
Re: BT Infinity Speed Issues - Again!!
Sounds like they aren't fixing anything, just resetting your IP Profile.
If not, I'll try again 🙂
Message 3 of 10
Thanks Ray, any idea how I should proceed with BT, I have them on the phone now.
Distinguished Guru
Message 4 of 10
Request a boost engineer, who will actually do something - find and fix the fault.
Message 5 of 10
Thanks! 😉
Message 6 of 10
UPDATE: I have sent an email to Gavin Patterson regarding my issue and am awaiting a response.
Message 7 of 10
Mr Patterson got his team to swing into action and I was assigned a UK Executive to personally deal with my issue. Issue is now resolved, but we are monitoring it for the next few days....;-)
Distinguished Guru
Message 8 of 10
What happened, did an engineer come?
Message 9 of 10
Engineer found no fault on the line. Swapped from BT Hub 4 to BT Hub 5 and speed increased to 75.12Mbps d/l and 16.47Mbps u/l.
Distinguished Guru
Message 10 of 10
That looks like the same thing as your original post.
Hope it works for you 😉
