martinlovell
Message 1 of 5
BT Infinity Speeds - Terrible
Hi all,
Contact BT this morning as the speed test on their website was showing 39.9MB being sent to my house, my wireless connection was only picking up 16MB although I have a GB wireless card - connected by ethernet cable and got 20MB, went through all the tests and they raised a fault on my line.
Just checked and they are saying this is not fixed but the BT wholesale speed test is showing 21MB - surely there is something wrong if they are saying I should be acheiving 39MB but I can not with the equipment they have provided to me?
Any answers?
Martin
4 REPLIES 4
arworsfold
Message 2 of 5
Re: BT Infinity Speeds - Terrible
similar here I only get between 5 and 8 mbs and live over the road from the exchange . Robbing ba.....ds
ray_dorset
Distinguished Guru
Message 3 of 5
Sounds like you are running Wireless-G not Wireless-N.
If not, I'll try again 🙂
martinlovell
Message 4 of 5
YES RESULT - went out and got a TPLink Wireless N USB adapter, changed my home hub channel to channel 1 and am now getting 36MB over wireless to my machine.
Ray your are a legend - thank you so much for your advice - I am a very happy person now.
Cheers
Martin Smiley Happy
ray_dorset
Distinguished Guru
Message 5 of 5
Nice one 😉
