Message 1 of 12
BT Infinity Wifi Download Speed
Hi,
I got BT Infitinty switched on yesterday, but when I do a speed test with the ethernet cable I get a download of 32.12 and upload 7.88.
But when doing a speedtest on wifi my download speed is 6.56, which to be honest I'm rather disappointed at.
Should the wifi speed be like this?
11 REPLIES 11
Message 2 of 12
Re: BT Infinity Wifi Download Speed
download speed over wireless is only as good as your wireless conenction which can vary from room to room in your home.  there is no guarantee on wireless download speeds for that very reason.  as speed appears on on ethernet you may need to boost your wireless signal about your home with wireless power adapter
Message 3 of 12
Thanks for your reply.
I understand there is no guarantees with using wifi, but would of thought it would have been better especially when I'm next to the smart hub.
Message 4 of 12
did you split the 2.4/5ghz bands as some devices don't like them  combined
you can also try changing the wireless mode from default mode 1
Message 5 of 12
havent touched any of the split as I just got the new smart hub last week
Message 6 of 12
just checked it is set to 5GHz
Message 7 of 12
what is - the device?
Sage
Message 8 of 12
That's the rub though, what device? Channels split? Drivers updated? No wonder ISP's don't give any guarantee on wireless connectivity.
Message 9 of 12
5GHz is set on BT Smart Hub 6
Sage
Message 10 of 12
What do you mean it's set? The hub broadcasts on both 2.5 and 5GHz channels, why set it on just oneed?
