spluff
Expert
Message 621 of 660
Re: BT Infinity and Fifa routing issues continued....
I'm using ps4 default settings playing fifa 14 ultimate team
The router is set up same as yours (dmz and qos settings)
Firmware is default what came with router ( I don't really wanna change it coz I may have to take it back and not sure if can revert to standard. )
Seamie
Message 622 of 660
Have you changed the settings on the ps4 after you installed the router?  Make sure the MTU matches on both console and router.
spluff
Expert
Message 623 of 660
I did a redetect automatic network setup
Mtu on console is set as automatic - do I need to manual put value in?
Seamie
Message 624 of 660
Before you try anything go to the asus website and get the latest firmware, the one you're using might be a year old.
Its original firmware so you will still be able to leave t back and if you get it working then you can put CFW on if you like.
spluff
Expert
Message 625 of 660
I can revert back? Whats cfw?
Seamie
Message 626 of 660
I set the MTU manually just to be sure.
Do you notice any difference?
Seamie
Message 627 of 660
CFW Custom Firmware, its made by enthusiasts for free which are sometimes better that the manufacturers stock firmware.  You can revert back by doing a factory reset.
spluff
Expert
Message 628 of 660
I dont see firmware 3.0.0.4.374.39 which yours is
Mine currently is 3.0.0.4.276
I think the latest version on website is 3.0.0.4.374.4561
What should I do - is 3.0.0.4.374.4561 okay?
ta for your help
Seamie
Message 629 of 660
Mine is cfw by Merlin.
I tried it on the asus fw before I put the Merlin fw on and it was lag free.  Try it with the new asus fw and if it doesn't work try tweaking the up and download limits with QoS.  I have also changed the dns server on mine, you can try that but I'm not sure if that will make a difference.
Seamie
Message 630 of 660
Choose global when downloading the firmware from asus
