Message 641 of 660
Re: BT Infinity and Fifa routing issues continued....
Try tweaking the upload speed, try it at 350kbps and then 900kbps to see if you notice any difference.
I read that fifa on ps4 uploads 26.7mb in an hour so you shouldn't need much.  Are you streaming to twitch?
When you setup your ps4 connection what were your estimated speeds?
Message 642 of 660
Something I noticed was when I was checking the ip of opponents before I applied QoS that the "state" of the connection was unreplied and when QoS was on the "state" was assured.
You can check this by going to system log then connections and when you're connected to your opponent press refresh.
Message 643 of 660
Have you setup your dns server on the ps4 to match the new servers in the router?
Expert
Message 644 of 660
nope I can add that aswell - ill try now
ill add dns change qos and check log
i aint streaming anything
Message 645 of 660
Spluff,  I've just checked my settings on the ps3 and my dns setting are
Primary dns = my router ip
secondary dns = 0.0.0.0
Expert
Message 646 of 660
ok  mate will try with that setting after cup match.....
im not holding my breath on it to be honest - i think i have nearly tried all options i can do
Expert
Message 647 of 660
nope still laggy and checked connection said assured and he was uk player on virgin and was not laggy for him..........
WHAT A LOAD OF **bleep**! I REALLY HAVE HAD ENOUGH
Message 648 of 660
Apart from lowering your upload speed so much that you force the other player to be host I'm not sure what else can be done.
Maybe read http://huaweihg612hacking.files.wordpress.com/2011/11/hg612_unlock_instructions_v1-3.pdf I have mine unlocked but the only thing I did was switch the btagent off.
Expert
Message 649 of 660
I really cant imagine that would help as I get lag on the hh5....
The lagging happens if im the host or if im not the host......
Sometimes games will start not laggy but then suddenly will start lagging - this is occurring against UK Fibre players and UK Virgin Players - where the game IS NOT LAGGING FOR THEM!
I have spent so much time, money and effort trying to resolve this. I NEED some help BT....
Expert
Message 650 of 660
just played another player on BT - he was so laggy from start
Ive turned of the QOS
udp 192.168.1.149:3659 217.43.198.27:3659 UNREPLIED
