captainqwerty
Message 1 of 36
BT Infinity and TP-LINK TD-W8980
Hello all,
I have recently purchased a TP-LINK W8980 router and I am having issues replacing my BT Home Hub with it.
Could anyone please help me with the configuration? Or better yet has anyone else got this router working on a BT Infinity connection.
I spoke to support and I used the details they provided me for the settings for the WAN connection and they just do not seem to work.
Thank you,
Antony.
35 REPLIES 35
licquorice
Message 2 of 36
Re: BT Infinity and TP-LINK TD-W8980
I assume you are connecting to the Openreach Modem, what settings were you given? Set WAN port to PPPoE, username--------anything@btbroadband.com, no password needed. If router insists on password just enter anything.
captainqwerty
Message 3 of 36
If the open reach modem is that little white box that the guy mounted wonky on the wall and it drives me nuts then indeed sir I am.
I have tried PPPoE and several usernames including the stuff BT support gave me.
They also siad on the support it was PPPOA which I have also tried to no avail 😞
licquorice
Message 4 of 36
Silly question, confirm you are configuring LAN4 port as a WAN port and Operation Mode to 'Wireless Router Mode'
Edit: Set VPI=0, VCI=38
licquorice
Message 5 of 36
Just looking at the user guide, you need to set the WAN service as 'PPPoE' tick IPv4 but untick IPv6
captainqwerty
Message 6 of 36
Currently doing the things you suggested I had some of that configured how you said but not all.
I need to walk the dog going to try what has been mentioned here then will get back to you.
Do I use the username
bthomehub@btbroadband.com
or
firstname.lastname@btbroadband.com
Thank you for your help by the way this is very much apprechiated.
licquorice
Message 7 of 36
or
Either, the part before '@btbroadband' can be anything.
captainqwerty
Message 8 of 36
Right I would like to confirm this is resolved thanks to Licquorice.
I have got it working - Thank you so much
licquorice
Message 9 of 36
Glad you got it working.
DavidM
Moderator
Moderator
Message 10 of 36
Great result licquorice.
Cheers
David
