G4RHL
Message 11 of 36
Re: BT Infinity and TP-LINK TD-W8980
HI,
I noticed you got your TP-Link TD-W8970 and wonder if you can confirm the final settings. I am on BT Infinity with a HomeHub 5 but have a TD-W8970 I want to use instead of the Home Hub. Have done a reset of the W8970. I have put in the user name which effectively is anything for the before the @ sign but have used bthomebub@btbroadband.com and the password of bt. It just does not connect and the ADSL light simply flashes telling me it is trying to.
I have tried putting in the default DNS settings I can read off the Home Hub but that does nothing.
Is there some other special setting I need to change? I am sure I have tried all the suggestions I have read on this site.
Thanks.
Richard.
G4RHL
Message 12 of 36
Reply to my own query. Have noticed am in a W8980 section and not WD8970! Will search on that.
licquorice
Message 13 of 36
If you have a HH5, I doubt you have the separate white modem. The WD 8970 is an ADSL router and won't work directly connected, it will only work connected to a VDSL modem.
007xico
Message 14 of 36
Hello,
Sorry but you tell me steps to get the n600 to work with open reach modem.
I can't get it working.
licquorice
Message 15 of 36
As described in earlier posts in this thread.
Edit: Which N600, it is a whole range?
lofagi788
Message 16 of 36
I have the same problem here, i got my infinity today, 'n i already bought a TP-LINK TD-W8980 N600 series. I did what you wrote down. Quick setup - vpi=0, vci=38 , then bthomehub@btbroadband.com as a username, blank password. That's all, but it couldn't connect. And ofc PPPoE and IPv6 unticked.
licquorice
Message 17 of 36
That's because the TD-W8980 is an ADSL modem, you need the 9980 which is VDSL.
Edit: I'm assuming you haven't got an Openreach modem as you have only just had Infinity installed.
lofagi788
Message 18 of 36
I've got my W9980 and it's working perfectly.
There is one question, wheen i turn enable the bandwith control my speed became half speed than before even without rules. Do you have any idea why?
licquorice
Message 19 of 36
@lofagi788 wrote:
I've got my W9980 and it's working perfectly. Great!
No idea, just tried it and I get a reduction in d/l from 37M to about 31M. Weird!! Might be worth asking TP-Link themselves.
Edit: I wonder if it applies some default bandwidth control to all connected devices before each is specified. I'll try again when there is only one device connected.
Further Edit: Nothing to do with the problem, but just to let you know there was a firmware update on the 15th Dec. The latest firmware is 0.6.0 1.10 v0021.0 Build 141215 Rel.41342n
licquorice
Message 20 of 36
Just tried again with only one device connected, still get the speed drop.
