Message 1 of 313
BT Infinity and https connection issues
I have sporadic issues with https connections on my BT Infinity service.
I used to be on Virgin ADSL and had no issues.
I can also use a Orange mobile dongle with no issues if I switch to that when experiencing problems with BT.
Some example sites:
Dixons checkout pages
NatWest banking pages
Anyone else experience this?
Should I periodically reboot the HomeHub and VDSL?
Cheers,
Jason.
312 REPLIES 312
Message 2 of 313
Re: BT Infinity and https connection issues
Sounds more like a problem with your browser or firewall. have you updated either?
Message 3 of 313
Thanks.
It is browser independent as I've tried on a few browsers.
I have McAfee Personal Firewall in use but wouldn't know what to change?
Also as I said it doesn't occur on same set-up using mobile dongle. So points to connection to me?
THANKS again.
Message 4 of 313
I've got the same issue!  NatWest login pages take ages (HTTPS) and Unity3D registration (HTTPS)
I know it's not an issue website-side as I've got a VPS in america that I connect to and can log into NatWest and send off my Unity3D registration there.
quigger, for reference I'm on Win7 64-bit, AVG and Windows Firewall.  Happens on all browsers.
Message 5 of 313
Well today I can't access https://www.bt.com/siteminderagent/forms/login.fcc (on any browser).
Computer issue? Nope, have tried it on two house computers and an Android phone for good measure, this is definitely either a modem/router issue or BT is doing something their side (e.g. throttling the non http ports to death)
Message 6 of 313
Update: It's specific sites. I can access other HTTPS sites (e.g. work e-mail through HTTPS - https://email.*****.co.uk/owa/)
What is going on ....?
Message 7 of 313
Can someone on Infinity kindly do me a test and visit https://upgrades.o2.co.uk/index.htm and tell me if it's darn slow for you too?  It's not the site as I'm loading up VNC and connecting to a VPS in America and it's instantly loading. It'll definitely rule out traffic shaping if someone on Infinity can tell me either way.
Thanks you generous souls!!!
Message 8 of 313
The page loads instantly for me.
Message 9 of 313
Pretty well instant for me on Safari via Infinity.
Message 10 of 313
Thanks both! Something to do with my side then. You've been a great help!
