Nigehol
Message 11 of 14
Re: BT Infinity avaliablility
Many thanks Guru Im keeping everything crossed that the Mods will get involved and sort the problem out
PaddyB
Moderator
Moderator
Message 12 of 14
Hi Nigehol,
Please can you send me in your details using the "Contact The Mods" link found in my profile. Once I have your details I'll see if I can find out anymore information.
PaddyB
Nigehol
Message 13 of 14
Hi PaddyB
Thanks for  help, my computer wont allow me to open the Contact the mlods link so will have contact you later if I can find another computer unless I can contact you in another format?
Nigehol
Message 14 of 14
Great result happened to look at availibility on Saturday pm and found BT Infinity now available at my address. Have now ordered and waiting to be hooked up. Thanks PaddyB
