Nigehol
Message 1 of 14
BT Infinity avaliablility
I need help. I have tried to gain infinity for months now and am getting nowhere. Openreach have sent me an email saying that there has been an error in data and that I should be able to gain infinity for my precise cabinet. But when I ring Sales at Bt or technical help they say its not available. It takes ages for a response from Openreach by e mail there is no phone number and BT just dont seem interested. Neighbours connected to the ssame cabinet have superfast. Surely somebody somewhere knows how I can resolve this problem, its drving me insane that nobody seems to care.
13 REPLIES 13
jac_95
Guru
Guru
Message 2 of 14
Re: BT Infinity avaliablility
Hi Nigehol,
If the Openreach FTTC infrastructure is already installed and your FTTC DSLAM cabinet (which will be connected to your PCP[cabinet]) has enough capacity to accept a new connection, and your within the distance that the VDSL2 signals can fatefully reach your property then it could defiantly be an issue within the BT Wholesale database.
Can you post the results for your landline from the BT Wholesale database by going to http://dslchecker.bt.com/adsl
remember to edit your landline number before clicking "Post"
Also compare this to your neighbours results, and post here. Again please edit the landline number and any personal info.
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Nigehol
Message 3 of 14
Results of cabinet data, see below. Neighbours details not available.
BT BROADBAND AVAILABILITY CHECKER
Downstream Upstream Featured Products Line Line Downstream Range(Mbps) Availability Date
Rate(Mbps) Rate(Mbps)
Up to 3.5 -- 2 to 6 Available
I
Up to 3.5 Up to 0.5 2 to 6 Available
ADSL Max Up to 2.5 -- 1.5 to 5 Available
WBC Fixed Rate 2 -- -- Available
Other Offerings
Fibre Multicast -- -- -- Available I
For all ADSL and WBC Fibre to the Cabinet (FTTC) services, the stable line rate will be determined during the first
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and
external to BT's network, Communication Providers' networks and within customer premises.
Jun-2014. The Stop Sale date for IPstream is from 30-Nov-2012; the Formal Retirement date for IPstream is
from 30-Jun-2014.
If the End User wishes to migrate from their current Broadband supplier they will need to contact them in the first
arrange for the service to be migrated.
Note: Please note that postcode and address check results are indicative only. Most accurate results can be
obtained from a telephone number check.
Thank you for your interest.
jac_95
Guru
Guru
Message 4 of 14
Nigehol,
maybe try the address checker for your nneighbour's. It's less accurate than the landline checker though is pretty decent : http://dslchecker.bt.com/adsl/ADSLChecker.AddressOutput
Try a Search
Nigehol
Message 5 of 14
Interesting resuly as below. Printing off details has lost some of the scrit but this seems to shoe that Infinity is available to my neighbour at the same cabinet. What do I do now please?
Address ....on Exchange DEVIZES is served by Cabinet 30
Downstream Line
Rate(Mbps)
High Low
(Clean)
18.4 12.8
WBC ADSL 2+
ADSL Max
Fixed Rate
Other
Offerings
Up to 2.5
Up to 2
1
1
Available
Taps) and/or Copper line conditions, and the term "Impacted" relates to a line which may have wiring issues
from 30-Jun-2014.
Note:
jac_95
Guru
Guru
Message 6 of 14
Nigehol,
What were the estimated FTTC ranges for your neighbour?
How far away are you from your neighbour?
As you may come under the Sub 15mbps Faster Unlimited broadband (FTTC) service, or could simple be too far away from your cabinet to get FTTC Fibre broadband
For example:
HighLowHighLow
FTTC Range A (Clean) 12.8 18.4 10.5 19.9 -- Available
FTTC Range B (Impacted) 9.6 12.7 10.5 19.9 -- Available
Try a Search
Nigehol
Message 7 of 14
Hi Guru,
Dont understand where I get the estimated FTTC ranges for my neighbour but this house is 20 yards further away from the cabinet than our house.
I can only think that the data being given for my property has still not been corrected so is my only option is to yet again return by e mail to openreach?
gg30340
Message 8 of 14
The moderators of the forum have been informed of your problem. Once they have read this they may be able to help. They are a BT UK based team and if they can help they will reply via this post.
Nigehol
Message 9 of 14
Thanks Guru I wait with baited breath. I hope that the moderators will take more interest than their colleagues who I have spoken to on the phone. They run to a script and just cant and dont know how to handle a situation which isnt on their list.
jac_95
Guru
Guru
Message 10 of 14
Nigehol,
As
If you are invited to contact the Mods you need to go the that Mod's profile (who invited you) and Click on the bit where it says "Click here to contact the mods" under the About Me section.
Once clicking on the Click here to contact the mods link you need to fill out the Contact Mods Form.
Please do not PM the Mods as this will not lead to your case being tracked properly. If the BTCare Team (Mods) offer you their help and support then the BTCare Contact form will become available to you.
Once contacting the BT care Team (Mods) they will reply either by phone or email usually within a couple of working days, however you will be given a tracking number immediately after sending the request. Please keep this safe.
Please be aware that this timeframe does not include weekends and Bank Holidays. The timeframe will also vary during busy periods.
Each case is done in a strict rotation so once your mod request has reached the top of the BTCare Team's inbox then they will contact you.
The BT Care Team are a BT UK Based specialist team who have a good reputation for solving customer problems.
Cheers
Try a Search
