WrappedUpInBlue
Message 1 of 10
BT Infinity - constant disconnections
The past month or so my BT Infinity has been dropping connection at random (seemingly every hour or so), all devices disconnect when this happens.  I have rebooted the HH, I have also done a reset, none of these have helped.  I've also tried disabling 5ghz, disabling UPNP and changing Wireless channel.   None of these have helped.
Here is part of the log from when it disconnected last.  The entries I have highlighted always coincide with the disconnect:
17:32:28, 07 Jun.(83706.340000) Lease for IP 192.168.1.66 renewed by host Kev-​PC (MAC 2c:81:58:f2:dd:1e). Lease duration: 1440 min
17:32:28, 07 Jun.(83706.340000) Device connected: Hostname: Kev-​PC IP: 192.168.1.66 MAC: 2c:81:58:f2:dd:1e Lease time: 1440 min. Link rate: 42.0 Mbps
17:32:28, 07 Jun.(83706.260000) Lease requested
17:32:28, 07 Jun.ath00: STA 2c:81:58:f2:dd:1e IEEE 802.11: Client associated
17:32:27, 07 Jun.ath00: STA 2c:81:58:f2:dd:1e IEEE 802.11: Client disassociated
17:32:27, 07 Jun.ath00: STA 00:62:2c:1b:a0:34 IEEE 802.11: WiFi registration failed
17:32:18, 07 Jun.(83696.420000) CWMP: session completed successfully
17:32:17, 07 Jun.(83695.860000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
17:32:16, 07 Jun.(83694.040000) Lease for IP 192.168.1.65 renewed by host android-​58b91f2baa31b1bf (MAC d0:5b:a8:62:60:65). Lease duration: 1440 min
17:32:16, 07 Jun.(83694.040000) Device connected: Hostname: android-​58b91f2baa31b1bf IP: 192.168.1.65 MAC: d0:5b:a8:62:60:65 Lease time: 1440 min. Link rate: 52.0 Mbps
17:32:16, 07 Jun.(83693.970000) Lease requested
17:32:15, 07 Jun.(83693.930000) Device disconnected: Hostname: tv2369ed3db747 IP: 192.168.1.68 MAC: 3c:77:e6:2a:3d:b9
17:32:15, 07 Jun.(83693.920000) Device disconnected: Hostname: android-​2c9596e2982e3cfb IP: 192.168.1.67 MAC: e8:50:8b:92:e1:2b
17:32:15, 07 Jun.ath00: STA 2c:81:58:f2:dd:1e IEEE 802.11: Client associated
17:32:15, 07 Jun.ath00: STA 2c:81:58:f2:dd:1e IEEE 802.11: Client disassociated
17:32:15, 07 Jun.ath00: STA d0:5b:a8:62:60:65 IEEE 802.11: Client associated
17:32:15, 07 Jun.ath00: STA 80:ea:23:2c:df:04 IEEE 802.11: Client associated
17:32:15, 07 Jun.ath00: STA 3c:77:e6:2a:3d:b9 IEEE 802.11: Client disassociated
17:32:15, 07 Jun.ath00: STA 80:ea:23:2c:df:04 IEEE 802.11: Client disassociated
17:32:10, 07 Jun.(83688.450000) Device disconnected: Hostname: tv2369ed3db747 IP: 192.168.1.68 MAC: 3c:77:e6:2a:3d:b9
17:32:10, 07 Jun.(83688.450000) Device disconnected: Hostname: android-​2c9596e2982e3cfb IP: 192.168.1.67 MAC: e8:50:8b:92:e1:2b
17:32:10, 07 Jun.(83688.450000) Device disconnected: Hostname: android-​58b91f2baa31b1bf IP: 192.168.1.65 MAC: d0:5b:a8:62:60:65
17:32:10, 07 Jun.ath00: STA d0:5b:a8:62:60:65 IEEE 802.11: Client disassociated
17:32:09, 07 Jun.(83687.820000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
17:32:09, 07 Jun.(83687.810000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
17:32:00, 07 Jun.(83678.650000) WAN operating mode is VDSL
17:32:00, 07 Jun.(83678.650000) Last WAN operating mode was VDSL
17:31:58, 07 Jun.(83676.760000) PPP IPCP Receive Configuration ACK
17:31:58, 07 Jun.(83676.750000) PPP IPCP Send Configuration Request
17:31:58, 07 Jun.(83676.750000) PPP IPCP Receive Configuration NAK
1. Product name:BT Home Hub
2. Serial number:+068343+NQ33832223
3. Firmware version:Software version 4.7.5.1.83.8.222.1.1 (Type A) Last updated 23/02/16
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 00:20:39
6. Data rate:19999 / 79903
7. Maximum data rate:26610 / 83746
8. Noise margin:15.1 / 6.9
9. Line attenuation:18.4 / 15.1
10. Signal attenuation:18.3 / 15.1
11. Data sent/received:1.1 GB / 6.5 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-M89Z
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 300 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:4
18. 5 GHz Wireless network/SSID:BTHub5-M89Z
19. 5 GHz Wireless connections:Disabled
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:18:62:2c:1b:a0:32
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
Any help would be gratefully appreciated.
9 REPLIES 9
smf22
Recognised Expert
Message 2 of 10
Re: BT Infinity - constant disconnections
Hi,
The CWMP event you see at 17:32:09 is a result of the line sync, not a cause of it. The router is configured to use CWMP to connect back and inform of changes in the value of certain parameters.
What events do you see before the PPP and WAN events at 17:31:58?
Regards
WrappedUpInBlue
Message 3 of 10
Thanks for the response, here are the logs from this morning when I went out up until 17:32, appears it has disconnected several times whilst I was at work:
17:31:56, 07 Jun.(83674.920000) CHAP authentication successful
17:31:56, 07 Jun.(83674.850000) CHAP Receive Challenge
17:31:56, 07 Jun.(83674.850000) Starting CHAP authentication with peer
17:31:56, 07 Jun.(83674.840000) PPP LCP Receive Configuration ACK
17:31:56, 07 Jun.(83674.840000) PPP LCP Send Configuration Request
17:31:56, 07 Jun.(83674.840000) PPP LCP Receive Configuration Reject
17:31:56, 07 Jun.(83674.840000) PPP LCP Send Configuration ACK
17:31:56, 07 Jun.(83674.840000) PPP LCP Receive Configuration Request
17:31:56, 07 Jun.(83674.830000) PPP LCP Send Configuration Request
17:31:14, 07 Jun.(83632.820000) CWMP: session closed due to error: No response
17:31:14, 07 Jun.(83632.800000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
17:31:14, 07 Jun.(83632.790000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
17:31:05, 07 Jun.(83623.210000) PTM over DSL is up
17:30:44, 07 Jun.(83602.370000) CWMP: session closed due to error: No response
17:30:40, 07 Jun.(83598.220000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
17:30:40, 07 Jun.(83598.210000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
17:30:39, 07 Jun.(83597.780000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
17:30:33, 07 Jun.(83591.840000) PTM over DSL is down after 384 minutes uptime
17:30:33, 07 Jun.(83591.830000) PPPoE is down after 383 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
17:30:29, 07 Jun.(83586.950000) PPP LCP Send Termination Request [User request]
17:01:58, 07 Jun.(81876.320000) Lease for IP 192.168.1.66 renewed by host Kev-​PC (MAC 2c:81:58:f2:dd:1e). Lease duration: 1440 min
17:01:58, 07 Jun.(81876.320000) Device connected: Hostname: Kev-​PC IP: 192.168.1.66 MAC: 2c:81:58:f2:dd:1e Lease time: 1440 min. Link rate: 29.0 Mbps
17:01:58, 07 Jun.(81876.230000) Lease requested
17:01:58, 07 Jun.ath00: STA 2c:81:58:f2:dd:1e IEEE 802.11: Client associated
16:59:52, 07 Jun.(81750.620000) Lease for IP 192.168.1.68 renewed by host tv2369ed3db747 (MAC 3c:77:e6:2a:3d:b9). Lease duration: 720 min
16:59:52, 07 Jun.(81750.620000) Device connected: Hostname: tv2369ed3db747 IP: 192.168.1.68 MAC: 3c:77:e6:2a:3d:b9 Lease time: 720 min. Link rate: 108.7 Mbps
16:59:52, 07 Jun.(81750.530000) Lease requested
16:59:51, 07 Jun.(81749.840000) Device disconnected: Hostname: Kev-​PC IP: 192.168.1.66 MAC: 2c:81:58:f2:dd:1e
16:59:51, 07 Jun.(81749.840000) Device disconnected: Hostname: android-​2c9596e2982e3cfb IP: 192.168.1.67 MAC: e8:50:8b:92:e1:2b
16:59:48, 07 Jun.(81746.320000) Lease for IP 192.168.1.64 renewed by host PS4-​80-​ea-​23-​2c-​df-​04 (MAC 80:ea:23:2c:df:04). Lease duration: 1440 min
16:59:48, 07 Jun.(81746.320000) Device connected: Hostname: PS4-​80-​ea-​23-​2c-​df-​04 IP: 192.168.1.64 MAC: 80:ea:23:2c:df:04 Lease time: 1440 min. Link rate: 105.6 Mbps
16:59:48, 07 Jun.(81746.250000) Lease requested
16:59:47, 07 Jun.ath00: STA 3c:77:e6:2a:3d:b9 IEEE 802.11: Client associated
16:59:46, 07 Jun.ath00: STA 80:ea:23:2c:df:04 IEEE 802.11: Client associated
16:59:46, 07 Jun.ath00: STA 3c:77:e6:2a:3d:b9 IEEE 802.11: Client disassociated
16:59:46, 07 Jun.ath00: STA 3c:77:e6:2a:3d:b9 IEEE 802.11: Client associated
16:56:40, 07 Jun.(81558.060000) Lease for IP 192.168.1.65 renewed by host android-​58b91f2baa31b1bf (MAC d0:5b:a8:62:60:65). Lease duration: 1440 min
16:56:40, 07 Jun.(81558.060000) Device connected: Hostname: android-​58b91f2baa31b1bf IP: 192.168.1.65 MAC: d0:5b:a8:62:60:65 Lease time: 1440 min. Link rate: 2.0 Mbps
16:56:40, 07 Jun.(81557.990000) Lease requested
16:56:36, 07 Jun.(81554.340000) Lease requested
16:56:36, 07 Jun.(81554.160000) Device disconnected: Hostname: Kev-​PC IP: 192.168.1.66 MAC: 2c:81:58:f2:dd:1e
16:56:36, 07 Jun.(81554.160000) Device disconnected: Hostname: android-​2c9596e2982e3cfb IP: 192.168.1.67 MAC: e8:50:8b:92:e1:2b
16:56:32, 07 Jun.(81550.650000) Lease requested
16:56:32, 07 Jun.ath00: STA d0:5b:a8:62:60:65 IEEE 802.11: Client associated
16:47:19, 07 Jun.(80997.210000) CWMP: session completed successfully
16:47:18, 07 Jun.(80996.900000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
16:47:16, 07 Jun.(80994.570000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
16:47:16, 07 Jun.(80994.560000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
16:47:16, 07 Jun.(80994.130000) CWMP: Initializing transaction for event code 2 PERIODIC
16:36:07, 07 Jun.(80325.710000) OpenWiFi IPSec connection is down
16:20:47, 07 Jun.(79405.410000) OpenWiFi IPSec connection is up
14:57:20, 07 Jun.(74398.280000) Lease for IP 192.168.1.68 expired. MAC: 3c:77:e6:2a:3d:b9, host name: tv2369ed3db747
14:42:39, 07 Jun.(73517.060000) OpenWiFi IPSec connection is down
14:27:36, 07 Jun.(72614.450000) OpenWiFi IPSec connection is up
13:18:58, 07 Jun.(68496.940000) Device disconnected: Hostname: Kev-​PC IP: 192.168.1.66 MAC: 2c:81:58:f2:dd:1e
13:18:58, 07 Jun.ath00: STA 2c:81:58:f2:dd:1e IEEE 802.11: Client disassociated
13:18:46, 07 Jun.(68484.680000) Lease for IP 192.168.1.66 renewed by host Kev-​PC (MAC 2c:81:58:f2:dd:1e). Lease duration: 1440 min
13:18:46, 07 Jun.(68484.680000) Device connected: Hostname: Kev-​PC IP: 192.168.1.66 MAC: 2c:81:58:f2:dd:1e Lease time: 1440 min. Link rate: 42.0 Mbps
13:18:46, 07 Jun.(68484.600000) Lease requested
13:18:46, 07 Jun.ath00: STA 2c:81:58:f2:dd:1e IEEE 802.11: Client associated
11:07:19, 07 Jun.(60597.130000) CWMP: session completed successfully
11:07:18, 07 Jun.(60596.940000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
11:07:11, 07 Jun.(60589.210000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
11:07:11, 07 Jun.(60589.200000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
imjolly
Message 4 of 10
the conenction time is only 20min was that a manual reset?
WrappedUpInBlue
Message 5 of 10
It wasn't a manual reset, seems entirely random when it goes out.  I did a clear line test and that seemed fine, speed tests are ok too.
imjolly
Message 6 of 10
are you using test socket to eliminate your setup and internal wiring from causing the problem?
WrappedUpInBlue
Message 7 of 10
I haven't done so as of yet, I will endeavour to do so though.  On second thoughts, I'm using the newer type of socket so I can't can I?
The socket is an Infinity SSFP socket.
imjolly
Message 8 of 10
smf22
Recognised Expert
Message 9 of 10
The first log message of significance is the one at 17:30:29, where the Home Hub sent a PPP termination request. There's nothing to indicate why it did this though. It could have been noise or interference on the line that caused it. As the line had been up for just over six hours at that point, there was presumably another event on your line just around 11.00 o'clock that's not shown.
Not sure what the weather was doing in your part of the country today, but the "event" might have been related to weather. My line stats were all over the place during the thunder/lighting we had earlier.
As you have a HH5A you might want to consider installing the RouterStatsHub software on a PC to monitor the HH DSL line stats. This would give an indication of how your line behaves throughout the day.
Regards
WrappedUpInBlue
Message 10 of 10
From looking back through the logs it does all seem to be PPP Termination Requests, this has been happening for the past month.  I've installed RouterStatsHub now and will leave it on to monitor the connection.
