Nathan09
Message 1 of 10
BT Infinity enabled for neighboring streets but not mine!
I recently received a letter letting me know that my local cabinet has been upgraded to fibre and I would be able to receive BT Infinity. As you can see below, Openreach confirms that it is now fibre enabled.
However, I've tried multiple times to upgrade to BT Infinity but BT keep telling me that it is not available, only their regular broadband is.
I decided to do some digging and started searching other addresses close to mine to see if they can receive BT Infinity and found that the street next to mine can but I cannot!
Neighboring StreetNeighboring StreetMy StreetMy Street
And as you can see by the GoogleMaps shot below, these streets are directly next to eachother!
Should this be happening? I am going to contact BT today to see what they say but I believe excluding a single street from having fibre is completely ridiculous!
9 REPLIES 9
Webby
Message 2 of 10
Re: BT Infinity enabled for neighboring streets but not mine!
Is the street that can get it, connected to the same cabinet as yours?
Nathan09
Message 3 of 10
I've just had a quick check and yes, it looks like I'm connected to the same cabinet.
Webby
Message 4 of 10
Then it would appear that due to the routing of the cables from the cabinet, your line is too long to support VDSL2 (the technology used to provide broadband from the fibre cabinets).
imjolly
Message 5 of 10
looks like you can get faster broadband which is the same as infinity  but for customers where conenction speed is 15mb or less.
if you are existing bt customer then try options team on 0800800030 and see if you can upgrade tp faster broadband - assuming that is better then your current adsl connection
Webby
Message 6 of 10
Apologies, I thought that was an adsl speed estimation.
Nathan09
Message 7 of 10
But why can't I get the same as my neighboring streets? There is a street just up past the M62 which can get up to 40mps and they are further away from the exchange?
john46
Message 8 of 10
fibre services come from the street cabinet not the exchange and what speed you get is dependent on your line length from the cabinet to your home phone lines do not run in the most direct route
Webby
Message 9 of 10
Your line is longer than theirs from the cabinet and the longer the line, th more the speed degrades. It's simple physics.
imjolly
Message 10 of 10
as you can see from graph how vdsl drops speed far faster than adsl of distance
