Grumpy_Customer
Message 1 of 4
BT Infinity in Grimsby?
Hello,
Please can a forum mod find out if/ when Grimsby area will have access to BT Infinity?
Exchange:- Healing
My Postcode:- DN37 9EU
The Healing exchange serves nearly 6000 properties, and mainly services the more ''well off'' areas of Grimsby, we are stuck on 2meg ADSL Broadband and I'm sure the uptake of FTTC would be massive success in the area.
Another reason why we left BT and went with VM!
Thank you
3 REPLIES 3
Message 2 of 4
Re: BT Infinity in Grimsby?
Mods have access to the same info as you do as a customer. Check the Wholesale line checker, if nothing on there then that's all that's available at the moment.
I hope you're not insinuating because it's a more affluent area it should get preferential treatment? 😉
Grumpy_Customer
Message 3 of 4
No, not at all...
People served by the main Grimsby exchange are lucky enough to have ADSL2+ enabled and a wider range of LLU providers to choose from.
Message 4 of 4
here you go this is link to the Openreach site http://www.superfast-openreach.co.uk/where-and-when/you can keep an eye on there as well
