The checker says that my postcode isn't served even though TRING is enabled and a friend of mine just up the road has got Infinity. The FAQ suggests that cabinet information is available from 29th September but the page with the link doesn't show any cabinet information. Is such information actually available ?
How far from an enabled cabinet does one need to be before the service becomes unavailable ?
When I spoke to someone about it they said something about a computer problem and that it was uncertain whether it is available or not at my address. Seems a bit of a shambles!
Doug
you may get more information from this site http://www.superfast-openreach.co.uk/where-and-when/
if you see a yellow pin then click on it and you will be able to see infomation about your cabinet
Thanks John, but there's no yellow pins on the map anywhere in the area despite the Tring exchange being enabled.
Doug
