Blueboy777uk
Message 1 of 4
BT Infinity is disconnected, sign-in required
Afternoon all,
First time posting so I'll try and explain as best I can.
Signed up to BT Infinity at home on the strength of how good it has been at work (flawless for 3 years and only needed 2 router restarts during that time). Initially for the first couple of weeks it was brilliant and a vast improvement on my previous broadband.
About 7 days ago, my devices started dropping their wi-fi connections and giving the message that BT xxx-xxx had been disconnected and sign in was required. Initially I thought nothing of it and simply reconnected as the problem occured. I assumed it was possibly either some fault of the device or possibly as a result of me disabling the smart connect wizard on the router.
Yesterday when the problem occured I logged into the Homehub 5 and it was clearly showing the the fault is the line dropping out, connection time was less than 2 minutes. I restarted the hub several times but think that the fault exists on the line itself. Have run the online fault checker / diagnostics and got the helpful "Sorry somethign went wrong" message.
Anyone else had this or similar? I want to try every fix possible before calling the helpline...
Thank you for reading.
3 REPLIES 3
imjolly
Message 2 of 4
Re: BT Infinity is disconnected, sign-in required
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
are you using the test socket with a new filter?
can you enter your phone number and post results  remember to delete number wholesale FTTC check
try quiet line test   dial 17070 option 2  should be quiet and best with corded phone
Blueboy777uk
Message 3 of 4
Thank you for those tips.
The results from the FTTC check -
Telephone Number xxxxxxxxxx on Exchange BOLSOVER is served by Cabinet 1
FTTC Range A (Clean)22.816.35.23.2--Available
FTTC Range B (Impacted)17.47.141.1--Available
WBC ADSL 2+Up to 5--3 to 7.5Available
WBC ADSL 2+ Annex MUp to 5Up to 13 to 7.5Available
ADSL MaxUp to 4--2.5 to 7Available
WBC Fixed Rate2----Available
Other Offerings
FTTP on Demand33030--Available
Fibre Multicast------Available
Copper Multicast------Available
The other tests I will perform when I get home. Thanks again for the swift response! 🙂
Blueboy777uk
Message 4 of 4
I can confirm that I am using a new filter also.
