Newbie
Message 1 of 2
BT Infinity multi-device connection issue
I am having problems in connecting multiple devices for last few weeks. I normally use 3-4 devices at a time and since last few weeks suddenly sometimes all devices gets disconnected. But mostly 1-2 devices face issue in connecting with either wifi or even LAN. Is this common problem? Any suggestions how to resolve this issue. I have restarted the devices and the hub which kind of fixes the probelm for a while but then again same problem occurs. Please help
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: BT Infinity multi-device connection issue
I suggest you try a factory reset of the hub
http://bt.custhelp.com/app/answers/detail/a_id/11386/~/how-do-i-reset-my-bt-home-hub-to-its-factory-...
If not, I'll try again 🙂
