Hi,
I've been told by one of my neighbours that we will never get fibre broadband as our cabinet has been removed from the upgrade plans?? Our postcode is NE22 5HE, how can I check if this is the correct info?
Hello,
I have been informed by enginners working on a new FTTC cabinet directly next to my original green cabinet, they have told me that they have been installing BT Infinity. I know that i am connected to this cabinet and it it part of phase 8a, other surrounding area have had their cabinet go live a few days ago but mine hasn't. Several websites such as Samknows are showing that FTTC is available at my address, but the BT fibre checker suggests otherwise. Is this just because the website hasn't updated correctly? Please help.
Postcode = NN4 0NG
samknowes only shows if your exchange is enabled for fibre not your address
@lshmcon wrote:Hello,
Postcode = NN4 0NG
Hi, i've just checked and the rollout phase for your area is due to be upgraded between now and September. The best thing to do is keep an eye on the Infinity checker here: www.bt.com/infinity
That will have the most recent and up to date information.
Post code : NE22 6DJ
Other parts of the NE22 postcode in the same area have already been fibre'd, would you be able to let me know of/when my local cabinet is to be done ?
Are they doing the 'long' runs of fibre first, as I live relatively closer to the exchange than my parents (NE22 5AH) and they are fibre enabled already
Many thanks
My post code is NE27 0EY
I have a 2 cabinets in my estate which have it and one of which is only 100 meters away (300 following the road)
a house I used to live in has the post code NE27 0EF which has bt infinity 2 enabled at it.
I cant locate my cabinet which I am connected to since I must be connected to another one since I cant get bt infinity, any help would be greatly appreciated 🙂
note: I live quite a far distance from my exchange so I don't think I am directly connected to it. Also I have received a letter saying bt infinity is coming soon... Yet that was nearly one and a half months ago. Also a bt engineer said that he was getting told to role out in the area that I live in and he said I should be able to get infinity when he is done but it doesn't look like I can.
@Capownz wrote:My post code is NE27 0EY
Hi, i just checked this for you and there are two cabinets attached to your postcode but both stating that there is no planned rollout of for fibre yet. However, this is based on a spreadsheet 6 months out of date so things could have changed by then.
Your exchange is not due for upgrade until September also and you don't have to be near the exchange to be connected directly to it, best way to check is here :https://www.btwholesale.com/includes/adsl/main.html enter your telephone number or address and this should tell you nearer the time if fibre will be rolled out to you.
I also live in Shiremoor and can't seem to find any information about when my cabinet will be upgraded. My postcode is NE27 0FQ, and the only information ic ould find is that i'm served by cabinet 63.
Is there anyway to find out when this cabinet is possibly earmarked for upgrade ?
