Message 1 of 12
BT Infinity replacement router
Hi all
Im looking to replace the HH3 with a 3rd party router, i only have £40-£50 max, can anyone recomend  a decent router for this kind of money please?
I was looking at getting one of these:
Asus RT-N12-C1 N300 Black Diamond Router
TP-Link 300Mbps Wireless-N Gigabit Router (TL-WR1043ND) [TL-WR1043ND]
But if anyone else knows of a better router for £40-50 that will be a great help
11 REPLIES 11
Message 2 of 12
Re: BT Infinity replacement router
Try looking for this one    TP-Link TL-WR1043ND about £42.
Expert
Message 3 of 12
Of the two I would go for the ASUS. It can be loaded with a custom firmware - Tomato - which has a good community for support and updates - http://en.wikipedia.org/wiki/Tomato_%28firmware%29
Message 4 of 12
As we're on the subject of new routers, what would be the best router to buy for anything up to £100?
Message 5 of 12
I use the Netgear 3700. Never failed me once 😉
Recognised Expert
Message 6 of 12
I use the TL-WR1043ND and D-Link Dir 825
both work without any issues
Message 7 of 12
I keep getting told on another forum, that unless a buy a Dlink 655 or a Asus RT-N56U, anything else i buy will be not good enough and i might as well keep the HH3?
Surely the routers ive listed will be better than the HH3?
What is your opinion of that guys?
Message 8 of 12
Hi walkerx
Can you confirm if the TL- WR1043ND is significally better than the Home Hub 3 as this is one of the routers i was looking at getting possibly
Expert
Message 9 of 12
The two routers mentioned have very fast WAN-LAN speeds which is the reason I had to dump my Draytek as it had a max throughput of around 35mbit/s.
http://www.smallnetbuilder.com/lanwan/router-charts/view
Th TP-Link is OK ish if you are on s strict budget but I wouldn't recommend it.
http://www.smallnetbuilder.com/wireless/wireless-reviews/31630-new-to-the-charts-tp-link-tl-wr1043nd...
Message 10 of 12
Hi Anthony, i have ordered the TP Link as my budget is limited unfortunately, im sure its going to miles better than the HH3 🙂
Im going to flash the FW with
http://wiki.openwrt.org/toh/tp-link/tl-wr1043nd
Ive also read several other reviews on the TL- WR1034ND that all prasie the router unlike the link you have provided.
I dont think i can get better for £45, i would love the Asus  RT-N56U but i cant afford the extra £40.
