Message 1 of 10
BT Infinity set up LAN X2
Hi,
I had the BT infinity Modem and HH4 installed today and everything is working fine.
I noticed that there are 2 Lan sockets on the Modem and I was wondering if I could plug in another router in to the Lan 2 socket.?
Thanks Keith
9 REPLIES 9
Message 2 of 10
Re: BT Infinity set up LAN X2
@keithsmythe wrote:
Hi,
Thanks Keith
The answer is no.
Why would you want to do that anyway?
Message 3 of 10
I just wondered if I could set up a seperate network on it.
Keith
Message 4 of 10
Keith
You only have one public IP address allocated, so a totally separate network would not be possible.
You can of course add additional ports to the home hub.
If you wanted a totally separate "Guest" network, then you would have to use a different router, like one of the Netgear range, that provide this facility.
A partial solution is to use a "smart" Ethernet switch, which has port based VLANs, which will isolate network segments.
Message 5 of 10
Thanks for the advice thats very helpful.
Keith
Message 6 of 10
One thing is a real shame is that the BT HH4 is does not have the latest wireless technology i.e 802.11ac which I understand is considerably faster than the 802.11n.
Regards
Keith
Message 7 of 10
The HH5 will have when it is released later this year
Message 8 of 10
Hi,
Will the BT HH5 be compatible with the bt Infinity Modem I had installed?
Keith
Message 9 of 10
The HH5 doesn't need an openreach modem, its built in.
Distinguished Expert
Message 10 of 10
The supplied Openreach modem is actually a fully featured modem/router but it is locked down to act as a modem though LAN1 only.
The user manual for the unlocked version is available here http://www.huaweidevice.com/worldwide/technicaIndex.do?method=gotoProductSupport&productId=3019
To say thanks for a helpful answer, please click the white star
