licquorice
Message 21 of 26
Re: BT Infinity set up - hub upstairs, masters/mains socket upstairs.
@semraoz wrote:
But they have different Mbps values which one would be suitable?
That is the speed they operate at, the figures are usually very optimistic. As IMJ says, 500 would be suitable. There are a number of different types of configuration, some have more than one Ethernet socket so multiple devices can be connected to one adaptor. Some have a 'plug through' facility which means the adaptor can also be used as a normal mains socket.
semraoz
Message 22 of 26
Also taking all this into account does this mean I can get rid of the long broadband cable that runs through the wall externally?
licquorice
Message 23 of 26
semraoz
Message 24 of 26
This is great thank you. Sorry for bothering you with all my questions this kind of stuff is trouble for me 😓
gg30340
Message 25 of 26
Your set up will be similar to this
semraoz
Message 26 of 26
Thanks this makes sense!
