Message 11 of 26
Re: BT Infinity set up - hub upstairs, masters/mains socket upstairs.
You can buy Ethernet cables separately, how long do you need them to be?
Message 12 of 26
You can just buy an Ethernet cable any length you require if the ones suppliespd are to short
Newbie
Message 13 of 26
I need about 4-5 metres but I've heard the standard size of the Ethernet cable that comes with the power line adapters are 2 metres. Also, is it true that using a power line setup can cause noise on your line and can reduce speeds of your connection?
Message 14 of 26
Powerline adapters can reduce your speed but still a good option for what you are trying to do instead of running a very long Ethernet cable. You can go to auction site and get cable any length you want
Message 15 of 26
A 5M Ethernet cable should cost you about £3/£4. The speed of connection will depend on the quality of your electrical wiring but shouldn't be a problem.
Newbie
Message 16 of 26
Thank you this really helps. Is there a specific type of Ethernet cable that I would need to buy?
Newbie
Message 17 of 26
Also do you know of a good quality power line adapter?
Message 18 of 26
BT sell then I use tplink
Newbie
Message 19 of 26
But they have different Mbps values which one would be suitable?
Message 20 of 26
Probably 500
