Message 1 of 2
BT Infinity:
Does anyone have any Idea when the nearest Infinity cabinet that has been installed for a month will be powered on and accepting orders? Postcode SR2 9NA cabinet is in Windermere Street and is number 55.
1 REPLY 1
Guru
Message 2 of 2
Re: BT Infinity:
Cabinet Probability Uplift Phase Status Type
P55 75% 10.12 8a Part of deployment FTTC (Fiber to the Cabinet)
N/A 24% Not part of a phase Directly connected to exchange. FTTC is not supported.
Basically by this information a quarter of your postcode is attached directly to the exchange and the rest are by cabinet.
If your unlikely enough to be that 24% that you won't unfortunately get any fibre. Your rollout phase is 8a which is around September time i think.
An exchange is deemed live or accepting orders and soon as the first cabinet on the exchange goes live.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
