StuartAJ
Message 1 of 1
BT Inspire 1500
I have had the unit for a couple of years now and it has now decided not to ring - either the base unit or the handset.
I've checked the following:-
The line receives calls and you can call out - the handset screen hi-lights up an incoming call - the handset batteries have been changed with appropriate delay for charging - the base is recieving power and working - all sounds are switched on to level 5 - paging handset works and rings ok.
The only problem is the unit does not ring for an external call and the answerphone doesn't answer.
Any ideas?
