Our Internet has gone down 4 times in the last hour. Not sure if this of any use but this is the technical log:
16:22:05 22 May. SIP WAN DOWN
16:22:01 22 May. SIP WAN DOWN
16:22:01 22 May. WAN Sensing Auto sensing Complete interface selected
16:22:01 22 May. WAN Sensing Auto sensing Running
16:22:00 22 May. WAN Sensing Auto sensing Complete interface selected
16:21:59 22 May. WAN Sensing Auto sensing Running
16:21:59 22 May. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
16:21:58 22 May. PPP: Stopped PPP daemon(0 1 5)
16:21:58 22 May. PPP LCP Send Termination Request (User request)
16:21:58 22 May. PPP: IPCP down
16:21:58 22 May. PPP: LCP down
16:21:58 22 May. DSL Link Down: duration was 642 seconds
16:21:52 22 May. admin timeout from 192.168.1.217
16:12:42 22 May. CWMP: HDM socket closed successfully.
16:12:42 22 May. CWMP: HTTP authentication success from pbthdm.x.x.x
16:12:42 22 May. CWMP: HDM socket opened successfully.
16:12:42 22 May. CWMP: session completed successfully
16:12:41 22 May. CWMP: HDM socket opened successfully.
16:12:40 22 May. CWMP: Server URL:
https://pbthdm.x.x.x; Connecting as user: ACS username
16:12:40 22 May. CWMP: Session start now server:
https://pbthdm.x.x.x Event code: 4 VALUE CHANGE
16:12:40 22 May. CWMP: Initializing transaction for event code 4 VALUE CHANGE
16:11:58 22 May. SIP WAN UP
16:11:55 22 May. NTP synchronization success
16:11:55 22 May. NTP Server: ntp.homehub.btopenworld.com
16:11:41 22 May. WAN Sensing Auto sensing Complete interface selected
16:11:41 22 May. WAN Sensing Auto sensing Running
16:11:40 22 May. WAN IPv6 Global unicast prefix / length: 2a00:23c4:19bb:3f00::/56
16:11:40 22 May. WAN IPv6 Global unicast address allocated: 2a00:23c4:19bb:3f00::1/64
16:11:40 22 May. WAN DHCPv6 events: BOUND
16:11:40 22 May. NTP synchronization start
16:11:39 22 May. WAN Sensing Auto sensing Complete interface selected
16:11:39 22 May. WAN DHCPv6 events: INIT
16:11:39 22 May. WAN Sensing Auto sensing Running
16:11:39 22 May. Success - secondary DNS servers
16:11:39 22 May. Success - primary DNS servers
16:11:39 22 May. WAN connection WAN2_INTERNET_PTM connected
16:11:38 22 May. PPP: IPCP up
16:11:38 22 May. PPP IPCP Receive Configuration ACK
16:11:38 22 May. PPP IPV6CP Receive Configuration ACK
16:11:38 22 May. PPP IPCP Send Configuration Request
16:11:38 22 May. PPP IPCP Receive Configuration NAK
16:11:38 22 May. PPP IPCP Send Configuration ACK
16:11:38 22 May. PPP IPCP Receive Configuration Request
16:11:38 22 May. PPP IPV6CP Send Configuration ACK
16:11:38 22 May. PPP IPV6CP Receive Configuration Request
16:11:38 22 May. PPP IPV6CP Send Configuration Request
16:11:38 22 May. PPP: CHAP authentication succeeded
16:11:38 22 May. PPP CHAP Receive success : authentication successful
16:11:38 22 May. PPP CHAP Receive Challenge
16:11:37 22 May. PPP: LCP up
16:11:37 22 May. PPP LCP Receive Configuration ACK
16:11:37 22 May. PPP LCP Send Configuration ACK
16:11:37 22 May. PPP LCP Receive Configuration Request
16:11:37 22 May. PPP LCP Send Configuration Request
16:11:37 22 May. PPP: Received PADS
16:11:37 22 May. PPP: Sending PADR
16:11:37 22 May. PPP: Received PADO
16:11:37 22 May. PPP: Sending PADI
16:11:32 22 May. PPP: Sending PADI
16:11:27 22 May. PPP: Sending PADI
16:11:24 22 May. DSL Link Up: Down Rate=159145kbps Up Rate=29236kbps; SNR Margin Down=13.4dB Up=11.3dB
16:11:22 22 May. PPP: Sending PADI
16:11:17 22 May. PPP: Starting PPP daemon
16:11:16 22 May. WAN Auto-sensing detected port DSL WAN
16:09:52 22 May. SIP WAN DOWN
16:09:47 22 May. SIP WAN DOWN
16:09:47 22 May. WAN Sensing Auto sensing Complete interface selected
16:09:47 22 May. WAN Sensing Auto sensing Running
16:09:46 22 May. WAN Sensing Auto sensing Complete interface selected
16:09:45 22 May. WAN Sensing Auto sensing Running
16:09:45 22 May. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
16:09:44 22 May. PPP: Stopped PPP daemon(0 1 5)
16:09:44 22 May. PPP LCP Send Termination Request (User request)
16:09:44 22 May. PPP: IPCP down
16:09:44 22 May. PPP: LCP down
16:09:44 22 May. DSL Link Down: duration was 2141 seconds
15:57:47 22 May. 5G Client associate from 38:8b:59:60:c1:3f (IP=192.168.1.124) RSSI=-39 Rate=433Mbps host
15:57:47 22 May. Receive a DHCP request
15:40:04 22 May. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
15:35:41 22 May. CWMP: HDM socket closed successfully.
15:35:41 22 May. CWMP: HTTP authentication success from pbthdm.x.x.x
15:35:41 22 May. CWMP: HDM socket opened successfully.
15:35:40 22 May. CWMP: session completed successfully
15:35:40 22 May. CWMP: HDM socket closed successfully.
15:35:40 22 May. CWMP: HTTP authentication success from pbthdm.x.x.x
15:35:40 22 May. CWMP: HDM socket opened successfully.
15:35:39 22 May. CWMP: Server URL:
15:35:39 22 May. CWMP: Session start now server:
15:35:39 22 May. CWMP: Initializing transaction for event code 4 VALUE CHANGE
15:35:19 22 May. Port forwarding rule added via UPnP/TR064. Protocol: UDP external ports: any->50501 internal ports: 50501 internal client: 192.168.1.111
15:34:44 22 May. SIP WAN UP
15:34:41 22 May. NTP synchronization success
15:34:41 22 May. NTP Server: ntp.homehub.btopenworld.com
15:34:28 22 May. WAN Sensing Auto sensing Complete interface selected
15:34:28 22 May. WAN Sensing Auto sensing Running
15:34:26 22 May. NTP synchronization start
15:34:26 22 May. WAN Sensing Auto sensing Complete interface selected
15:34:26 22 May. WAN IPv6 Global unicast prefix / length: 2a00:23c4:19bb:3f00::/56
15:34:26 22 May. WAN IPv6 Global unicast address allocated: 2a00:23c4:19bb:3f00::1/64
15:34:26 22 May. WAN DHCPv6 events: BOUND
15:34:26 22 May. WAN Sensing Auto sensing Running
15:34:26 22 May. Success - secondary DNS servers
15:34:26 22 May. Success - primary DNS servers
15:34:26 22 May. WAN connection WAN2_INTERNET_PTM connected
15:34:25 22 May. WAN DHCPv6 events: INIT
15:34:25 22 May. PPP: IPCP up
15:34:25 22 May. PPP IPCP Receive Configuration ACK
15:34:25 22 May. PPP IPV6CP Receive Configuration ACK
15:34:25 22 May. PPP IPCP Send Configuration Request
15:34:25 22 May. PPP IPCP Receive Configuration NAK
15:34:25 22 May. PPP IPCP Send Configuration ACK
15:34:25 22 May. PPP IPCP Receive Configuration Request
15:34:25 22 May. PPP IPV6CP Send Configuration ACK
15:34:25 22 May. PPP IPV6CP Receive Configuration Request
15:34:25 22 May. PPP IPV6CP Send Configuration Request
15:34:25 22 May. PPP: CHAP authentication succeeded
15:34:25 22 May. PPP CHAP Receive success : authentication successful
15:34:24 22 May. PPP CHAP Receive Challenge
15:34:24 22 May. PPP: LCP up
15:34:24 22 May. PPP LCP Receive Configuration ACK
15:34:24 22 May. PPP LCP Send Configuration ACK
15:34:24 22 May. PPP LCP Receive Configuration Request
15:34:24 22 May. PPP LCP Send Configuration Request
15:34:24 22 May. PPP: Received PADS
15:34:24 22 May. PPP: Sending PADR
15:34:24 22 May. PPP: Received PADO
15:34:24 22 May. PPP: Sending PADI
15:34:19 22 May. PPP: Sending PADI
15:34:14 22 May. PPP: Sending PADI
15:34:11 22 May. DSL Link Up: Down Rate=159111kbps Up Rate=29227kbps; SNR Margin Down=14.2dB Up=10.6dB
15:34:09 22 May. PPP: Sending PADI
15:34:04 22 May. PPP: Starting PPP daemon
15:34:03 22 May. WAN Auto-sensing detected port DSL WAN
15:32:49 22 May. SIP WAN DOWN
15:32:44 22 May. SIP WAN DOWN
15:32:44 22 May. WAN Sensing Auto sensing Complete interface selected
15:32:44 22 May. WAN Sensing Auto sensing Running
15:32:43 22 May. WAN Sensing Auto sensing Complete interface selected
15:32:42 22 May. WAN Sensing Auto sensing Running
15:32:42 22 May. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
15:32:41 22 May. PPP: Stopped PPP daemon(0 1 5)
15:32:41 22 May. PPP LCP Send Termination Request (User request)
15:32:41 22 May. PPP: IPCP down
15:32:41 22 May. PPP: LCP down
15:32:41 22 May. DSL Link Down: duration was 238 seconds
15:29:41 22 May. CWMP: HDM socket closed successfully.
15:29:41 22 May. CWMP: HTTP authentication success from pbthdm.x.x.x
15:29:41 22 May. CWMP: HDM socket opened successfully.
15:29:41 22 May. CWMP: session completed successfully
15:29:40 22 May. CWMP: HTTP authentication success from pbthdm.x.x.x
15:29:40 22 May. CWMP: HDM socket opened successfully.
15:29:39 22 May. CWMP: Server URL:
15:29:39 22 May. CWMP: Session start now server:
15:29:39 22 May. CWMP: Initializing transaction for event code 4 VALUE CHANGE
15:29:24 22 May. SIP WAN UP
15:29:21 22 May. NTP synchronization success
15:29:21 22 May. NTP Server: ntp.homehub.btopenworld.com
15:29:08 22 May. WAN Sensing Auto sensing Complete interface selected
15:29:08 22 May. WAN Sensing Auto sensing Running
15:29:06 22 May. NTP synchronization start
15:29:06 22 May. WAN Sensing Auto sensing Complete interface selected
15:29:06 22 May. WAN IPv6 Global unicast prefix / length: 2a00:23c4:19bb:3f00::/56
15:29:06 22 May. WAN IPv6 Global unicast address allocated: 2a00:23c4:19bb:3f00::1/64
15:29:06 22 May. WAN DHCPv6 events: BOUND
15:29:06 22 May. WAN Sensing Auto sensing Running
15:29:06 22 May. Success - secondary DNS servers
15:29:06 22 May. Success - primary DNS servers
15:29:06 22 May. WAN connection WAN2_INTERNET_PTM connected
15:29:05 22 May. WAN DHCPv6 events: INIT
15:29:05 22 May. PPP: IPCP up
15:29:05 22 May. PPP IPCP Receive Configuration ACK
15:29:05 22 May. PPP IPV6CP Receive Configuration ACK
15:29:05 22 May. PPP IPCP Send Configuration Request
15:29:05 22 May. PPP IPCP Receive Configuration NAK
15:29:05 22 May. PPP IPCP Send Configuration ACK
15:29:05 22 May. PPP IPCP Receive Configuration Request
15:29:05 22 May. PPP IPV6CP Send Configuration ACK
15:29:05 22 May. PPP IPV6CP Receive Configuration Request
15:29:05 22 May. PPP IPV6CP Send Configuration Request
15:29:05 22 May. PPP: CHAP authentication succeeded
15:29:05 22 May. PPP CHAP Receive success : authentication successful
15:29:04 22 May. PPP CHAP Receive Challenge
15:29:04 22 May. PPP: LCP up
15:29:04 22 May. PPP LCP Receive Configuration ACK
15:29:04 22 May. PPP LCP Send Configuration ACK
15:29:04 22 May. PPP LCP Receive Configuration Request
15:29:04 22 May. PPP LCP Send Configuration Request
15:29:04 22 May. PPP: Received PADS
15:29:04 22 May. PPP: Sending PADR
15:29:04 22 May. PPP: Received PADO
15:29:04 22 May. PPP: Sending PADI
15:28:59 22 May. PPP: Sending PADI
15:28:54 22 May. PPP: Sending PADI
15:28:51 22 May. DSL Link Up: Down Rate=159145kbps Up Rate=29227kbps; SNR Margin Down=13.4dB Up=10.7dB
15:28:49 22 May. PPP: Sending PADI
15:28:44 22 May. PPP: Starting PPP daemon
15:28:43 22 May. WAN Auto-sensing detected port DSL WAN
15:27:18 22 May. SIP WAN DOWN
15:27:15 22 May. WAN Sensing Auto sensing Complete interface selected
15:27:15 22 May. SIP WAN DOWN
15:27:14 22 May. WAN Sensing Auto sensing Running
15:27:13 22 May. WAN Sensing Auto sensing Complete interface selected
15:27:13 22 May. WAN Sensing Auto sensing Running
15:27:13 22 May. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
15:27:11 22 May. PPP: Stopped PPP daemon(0 1 5)
15:27:11 22 May. PPP LCP Send Termination Request (User request)
15:27:11 22 May. PPP: IPCP down
15:27:11 22 May. PPP: LCP down
15:27:11 22 May. DSL Link Down: duration was 1528 seconds
