pawan98
Message 1 of 4
BT KEEPS ON DISCONNECTING! :@
It just keeps on disconnecting, it takes about 30 seconds to get back up again, but I don't know why, it just keeps on disconnecting, and my wireless adapter and computer is fine, I assure you. My BtHomeHub3, is fine too. Also it seems to disconnect alot when someone calls.
3 REPLIES 3
Message 2 of 4
Re: BT KEEPS ON DISCONNECTING! :@
Hi try another filter they sometimes fail
Faux1235
Message 3 of 4
aw man i had this problem not more than one week ago 😞  know the feeling
i found this solution worked for me:
http://community.bt.com/t5/BB-Speed-Connection-Issues/Router-Disconnecting-from-internet-all-the-tim...
hope it works for you too !!! 🙂   good luck and hope you find the problem.
Message 4 of 4
try the quiet line test dial 17070 option 2  should hear nothing and best done with a corded phone (not BBtalk phone)
if you have any loud hiss or crackle then report a phone fault by dialling 151 do NOT report a broadband fault
