smparrott
Message 1 of 8
BT Level 3 - Is there anybody there and how do you contact them
I have an ongoing Broadband problem which BT don't seem to think exists despite the BT Wholesale speed checker showing there is. A 70mb connection guaranteed at 54mb down give a down spped of between 2 and 10 depending when  tested. Call centre absolutely useless, has been escalated to Level 3 apparently who yesterday were supposed to ring back!!!! Never happened.
Any one else know how to get BT to react and how to contact these supposed Level 3 people ?
7 REPLIES 7
Webby
Message 2 of 8
Re: BT Level 3 - Is there anybody there and how do you contact them
Is this only at peak times?
Can you post the connection stats from the router?
Can you run the BT Wholesale speedtest over an Ethernet cable with no other devices connecteted?
smparrott
Message 3 of 8
All the time not speciifc time of day, yes done the tests wired only one device, been told by Level 3 fault closed due to my attitude !!!!!!
BT sucks
Webby
Message 4 of 8
Can you post the hub stats and a screenshot of the BT Wholesale test please.
smparrott
Message 5 of 8
Do you work for BT Webby ?
Webby
Message 6 of 8
If you post up the information, there's lots of helpful folk on here.
If we feel we can't help, then a moderator can be notified who can step in. The moderators work for BT and have a great record of resolving issues.
They would ask to see what I've asked for before looking into it though.
smparrott
Message 7 of 8
OK Thanks for your help I am an IT specialist and have been for 30 years, I was just hoping someone from BT may take this one up
Webby
Message 8 of 8
As I said, you'll need to post up the information I asked for anyway. The mods would ask you to do that before taking it any further.
