Message 1 of 3
BT Logging is there anyproblems?
I only seem to disconnect on my laptop no other device.
Im seeing some blocked packages is that the problem?
17:51:32, 09 Jul.IN: ACCEPT [57] Connection closed (Port Forwarding: TCP  192.168.1.65:24005    <-->86.153.171.93:24005   [81.147.141.45:64268] CLOSED/SYN_SENT ppp1 NAPT)
17:50:50, 09 Jul.IN: ACCEPT [57] Connection closed (Port Forwarding: TCP  192.168.1.65:24005    <-->86.153.171.93:24005   [86.166.5.225:53180] CLOSED/SYN_SENT ppp1 NAPT)
17:50:49, 09 Jul.IN: ACCEPT [57] Connection closed (Port Forwarding: TCP  192.168.1.65:24005    <-->86.153.171.93:24005   [86.166.5.225:53179] CLOSED/SYN_SENT ppp1 NAPT)
17:50:10, 09 Jul.IN: ACCEPT [54] Connection opened (Port Forwarding: UDP  192.168.1.66:52913    <-->86.153.171.93:52913   [173.173.5.186:37147] ppp1 NAPT)
17:49:56, 09 Jul.IN: ACCEPT [54] Connection opened (Port Forwarding: UDP  192.168.1.65:24005    <-->86.153.171.93:24005   [188.169.136.20:14549] ppp1 NAPT)
17:49:34, 09 Jul.IN: ACCEPT [54] Connection opened (Port Forwarding: TCP  192.168.1.65:24005    <-->86.153.171.93:24005   [81.147.141.45:64273] CLOSED/SYN_SENT ppp1 NAPT)
17:49:32, 09 Jul.IN: ACCEPT [54] Connection opened (Port Forwarding: TCP  192.168.1.65:24005    <-->86.153.171.93:24005   [81.147.141.45:64268] CLOSED/SYN_SENT ppp1 NAPT)
17:48:53, 09 Jul.BLOCKED 2 more packets (because of Remote administration)
17:48:51, 09 Jul.BLOCKED 1 more packets (because of Remote administration)
17:48:51, 09 Jul.IN: BLOCK [16] Remote administration (TCP 86.166.5.225:53181->86.153.171.93:443 on ppp1)
2 REPLIES 2
pippincp
Sage
Message 2 of 3
Re: BT Logging is there anyproblems?
That log does not show a problem.
If you have one could you please explain in more detail?
ironman123
Recognised Expert
Message 3 of 3
The last 3 lines in that log are in effect saying that some packets [data] forwarded from the router are being blocked by the remote server or host that the data is being directed to.
The reason could be a remote setting fault or an intentional block.
For example the last line:
is saying that remote administration at 86.166.5.225 port 53181 is blocking the data and refering it to 86.153.171.93 on port 443,but do not know the reason.
But it could be the BT network routing the data to a ppp1 server [point to point protacol] server,but that happens a lot in big networks.
