Message 1 of 4
BT Login Password Security
The easy ones first - so how many characters - maximum - and of what type should we all be using ?
I have looked in all the usual places and have to report it just ain't out there.
3 REPLIES 3
Message 2 of 4
Re: BT Login Password Security
Hi @Anology
For email issues and questions best have a chat with the online BT Email Team they should be able to answer all your questions.
Message 3 of 4
If memory serves me correctly the maximum number is 32 and the minimum is 6. The password should have a mixture of Upper and lower case letters and numbers. Again from memory you can not use special characters although that may have changed.
See link about password in general.
https://bt.custhelp.com/app/answers/detail/a_id/9193
Message 4 of 4
Thank you Mr Memory.
Of course I will not be divulging my precise combination of letters, special characters and the such like here.
It has already been committed to memory.
And it's gone.
