I was thankfully 'upgraded' some time ago from BT Yahoo Mail to BT Mail.
It is an improvement but I want to change the default typeface to my choice permanently. I can't see how to do this.
Is it possible or is another of the BT's designers annoying restrictions? Or am I being unkind ?
Solved! Go to Solution.
From memory you can not change the default font permanently.
If you want to have that sort of control you should use an email client such as Thunderbird or the Windows Mail App if you have a Windows computer.
Thanks for that
I'd thought BT with all their resources could make it user friendly
Gmail has all the functionality you need and it can poll your BT email if you want it to
Thanks for that.
I will give it a go but why can't BT include this basic feature?
