Deano11
Message 1 of 6
BT Master Socket slower connection
This is a short question as im confused, I use a secondary socket in my room so that i can play xbox live, when upstairs i get a broadband reading of 448 Kbps on a good day, when i try my hub on the BT Master Socket i get a SLOWER connection of around 224 Kbps , Why is this?, you would think it would be the other way round.
5 REPLIES 5
Message 2 of 6
Re: BT Master Socket slower connection
those speeds make no sense are you on infinity
Deano11
Message 3 of 6
Deano11
Message 4 of 6
NilSatisOptimum
Recognised Expert
Message 5 of 6
Hi welcome to the forums,  Might be best if you post your stats
To post the full stats from your router
for home hub - 192.168.1.254
Navigate to ADSL Settings or use the A-Z at the top right
Click on More Details and then post the results.
Run BT speed tester and post the results from http://speedtester.bt.com/
Mortgage Advisor 2000-2008
Green Energy Advisor 2008-2010
Charity Health Care Provider Advisor 2010-
I'm alright Jack....
Message 6 of 6
you have changed all the original figure's you posted why
