Message 1 of 17
BT Master socket
The master socket is down stairs and I want it in one of the bed rooms now will the engineer when I order bt infinity install it for free or will I need to pay.
16 REPLIES 16
Recognised Expert
Message 2 of 17
Re: BT Master socket
The engineer will either:
1   Swap the wiring around if it is suitable to make an extension socket become the Master and vice-versa,
or
2   Install a Data Extension kit to provide an outlet where you wish within certain limits.
Message 3 of 17
Seems to be a lot of questions on Master sockets at the moment Smiley Very Happy
See my answers on the other threads, but I've (without issue) on a few occasions employed a local telecoms engineer to move the master socket to another existing socket in the property.  Cost for doing this is usualy £70 - £125 including parts and you can rest assured that you are using an expert.
This method means you aren't laying any further cables, pulling up any floorboards or chasing out any walls.   This won't work of course if you wish to fit the master socket where presently there isn't any cabling / exisiting socket.
Good luck.
Recognised Expert
Message 4 of 17
BT don't charge for the work done at the time of an Infinity connection.
Message 5 of 17
They can install a 30m cat5 extension for free!!! If you ask.
Message 6 of 17
When I got mine installed the cable came in via the lounge then went to the bedroom, the BT engr told me that it was too windy to put a new cable in, altered my wiring & told me I couldn't use the socket downstairs for a phone, Luckily I had corldess phones.
Message 7 of 17
They make phones with Cords on ???  Smiley LOL
Message 8 of 17
I know that but I couldn't plug a phone in downstairs because the bt engr used the socket downstairs as a joint box
Recognised Expert
Message 9 of 17
The engineer did that with mine and fitted an extension faceplate
Distinguished Guru
Message 10 of 17
They are the ones you use when there's a power cut and all the cordless phones stop working.
