Message 11 of 17
Re: BT Master socket
There is still the mobile phone!! Smiley Happy
Message 12 of 17
untill the phone network crashes that it have had it happen 2 or 3 times on me befor or what about if you cant get a signal? or the backup power supply to the phone mast dosnt kick in?
Message 13 of 17
Is there A massive difference in speed in your modem is plugged into an extension socket and not the master socket?
Message 14 of 17
Depends on the quality and layout of the internal wiring. With Infinity you can only use the socket that the engineer installs.
Message 15 of 17
I'm hoping this means (like my present master) that the new socket isolates the internal wiring in the flat and stops it interfering with the data signal.?
Message 16 of 17
It depends, I told the engineer to make that the only working socket but he said I could have others left working if I wanted.
Message 17 of 17
To be honest. As it's my place and I'm not selling it anytime soon I could ideally just have the 1 socket with a connection for the wireless phones (3 operate from 1 base station) and a connection for the Infinity.
This would then mean the rest of the cabling in the house was disconnected and unable to interferre.
Risky though as it's bound to cause a problem in the future knowing my luck - lol.
