DavidM
Moderator
Moderator
Message 11 of 16
Re: BT Max/BT UHD - at my wit's end
Thanks for letting us know you're sorted @Muttley33 and thanks to @Gemma_P for helping out with this.
Cheers
David
wwwebber
Message 12 of 16
@Muttley33 wrote:
Who knows? We're able to watch 2 simultaneous Netlix UHD streams in our house, but according to BT the line is not quick or stable to watch a single BT UHD stream?????
And @Gemma_P - the reason I'm given for not getting it is because of the speed returned by the BT Wholesale checker is too low - Have got another mod looking at this already.
Glad you got it sorted. However, your comparison with Netflix is not right. Netflix use a lower bitrate and also use adaptive technology to adjust the bitrate on the fly depending upon available linespeed. BT pushes the same fixed rate high quality UHD stream out to everyone. Therefore the comparison just doeant stack up.
david1982
Message 13 of 16
david1982
Message 14 of 16
Hi guys just connected my UHD box and all seems well except in settings it tells me I'm not connected to my router even though I'm watching channel 433, also unable to get drop-down to get mobile phone linked. Any suggestions. Welcome your advice.
david1982
Message 15 of 16
Hi again think I was a bit hasty after a few hours wait the box has settled down and things are all OK
DanielS
Moderator
Moderator
Message 16 of 16
That's perfect @david1982.
We'll be here if you ever need us
DanielS
